![]() i have a 1992 s13 fb
during idle my car will shake?.. nothing violent but a very noticable shake everyone who rides in my car comments about it ![]() what makes this weird is its only during idle/low rpms while driving it smooths out and feels normal it shakes up to 1400rpm then goes smooth i have surched this problem and heard everything from sparks/misfire to exhaust clog..but to no avail nothing fixed it please help thanks ALOT!!!!! ![]() |
I had the same problem on my hatch one of the cylinders was misfiring check your distributor/replace or check sparks to see which one is misfiring. You should change your motor mounts as well mine were done.
![]() Join Date: Jul 2008
check your injectors one could be malfunctioning as in leaking or clogged. the o rings could also be messed up.
disconnect each injector while idling. if you see no change in rpm drop then thats your culprit
![]() Quote:
![]() Join Date: Sep 2004
Mine did that for a while on my first S13 when the O2 sensor died.... have you checked for codes?
------------------------- www.carolinanissans.com ------------------------- |
i just changed all the spark plugs 3days ago
i bought the car 3 months ago and if it was the motor mounts wouldnt it shake hard as i decelerate or apply throttle? ill check the injectors asap stuff i forgot to mention: i have been burning oil (exhaust smells bad).... seems like from cylinder #2 because when i changed the sparks #2 was all gunkie n built up on the threads and even on the bolt part too one time i added injector cleaner and gas tank cleaner into my gas tank and the problem went away for a week or so?? |
OK i think the problem might be a misfire
![]() yes its gone for now but how do i keep it away this is the second time its came n gone? ![]() |
Banned from the Marketplace
sea foam this thing, check the mounts, spark plugs, timing if you can. and might wanna check the fuel pump see the condition of the pump/tank i have rust in my tank and thats what my car does and my car is a fresh swap and it had NO problems in my s14
#11 | |||
by checking your injectors and changing them if needed lol
![]() Quote:
#12 | |
Tags |
idle, shake |
