Old 07-09-2013, 09:33 AM   #1
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
Fried DOHC ECU's
I have 2 DOHC Ecus that are fried. both are fried on pin 36 and that is the Ignition Switch 12v.
Now I didnt check them before I installed to see if they were previously fried. Im currently trying to solder one and see if i can fix this issue with it.
Can someone tell me what to check to see if MY IGNITION is the one frying them. Also If I plug in a SOHC and it DOESNT FRY would you say that they were previously fried or is there a major difference between dohc and sohc ecu
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
