Old 12-24-2012, 12:27 PM   #1
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Send a message via ICQ to EDacIouSX Send a message via AIM to EDacIouSX Send a message via MSN to EDacIouSX Send a message via Yahoo to EDacIouSX
Post The WHP Database Thread SR/KA/RB/CA
It's time for zilvia to have a SR/KA/RB/CA power output database. Here's the deal, post up your mods and whp/wtq numbers WITH DYNO SHEETS (No dyno sheet no post)and I will do my best to accumulate all of the stats and put it on an excel sheet.
There will be a lot of info here and I'll need help. PM me if you're interested in helping maintain this sheet, will only consider long term zilvia members.
This is what I need (the more info the better):
Engine (S13 SR, S14 SR, R32 RB20, S13 KA24DE, S14 KA24DET, etc)
WHP and WTQ Numbers
Dyno Sheet
Turbo (if applicable)
PSI
Major Mods (stroker kit, intake manifold, SR20VET head on s13 block or s14/15 block, etc)
ECU
Cams
Gas/Fuel Type Used (E85, 93, 91, etc)
Example 1:
Engine: S13 SR20DET
WHP: 350 WHP 300 WTQ Dyno Sheet: www.dynosheetlink.com
Rods + Pistons: Oem
Injectors: 550CC
Compression: Stock
Turbo: HKS GT28RS w/ Tomei Exhaust Manifold
Manifold: Greddy Intake Manifold
Boost: 15 Psi
Cams: HKS Step 2 264/264
ECU: HKS F Con V Pro
Gas: 91
Example 2:
Engine: S14 KA24DE-T
WHP: 275 WHP 290 WTQ Dyno Sheet: www.dynosheetlink.com
Rods + Pistons: Oem
Injectors: 550CC
Compression: 9:1
Turbo: S14 T28 w/ Modded SR Stock Manifold
Intake Manifold: Stock Intake Manifold
Boost: 13 Psi
Cams: Brian Crower Cams 264/264
ECU: Nistune
Gas: 91
Here's the spreadsheet link
(Updated 9pm 12/30/12)
EDacIouSX is offline   Reply With Quote
Old 12-26-2012, 12:31 PM   #2
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
These are not my engines, just ones I have tuned and happen to have scanned dyno sheets of. Some of the info on the car I will not remember totally correctly.
Engine: vg33et
WHP:
Rods + Pistons:
Stock
Turbo: Holset, I cannot remember if it were an h1c or he351
Manifold: Arcadia or something of that nature
Boost: 20ish psi
Cams: 272
ECU: z31 with nistune
Gas: 93
Engine: s13 sr
WHP:
Rods + Pistons: ?
Turbo: 2871r
Manifold: stock
Boost: 20
Cams: stock
ECU: s13 sr nistune
Gas:93
This next one is the same car and turbo but with some mods including a better intake and intercooler and cams. I have made more power that both of these engines with a 2871 on a sr on pump gas. There was something with the engine or turbo that was holding it back.
Engine: s13 sr
WHP:
Rods + Pistons: ?
Turbo: 2871r
Manifold: greddy
Boost: 20ish
Cams: 264 I believe
ECU: s13 nistune
Gas: 93
Engine: s13 sr
WHP:
Rods + Pistons: I cannot remember, but I do believe it was a fresh forged bottom end with stock compression
Turbo: stock
Manifold: stock
Boost: 12psi
Cams: stock
ECU: stock+ nistune
Gas: 93
Engine: NA Ka24de
WHP: low numbers are stock tune, higher numbers are after my tuning
Rods + Pistons: Cannot remember rods, pistons were actually only 9:1
Turbo: NOPE
Manifold: stock intake, had exhaust hedder
Boost: Cold air intake
Cams: stock I believe
ECU: stock + nistune
Gas: 89
Engine: s13 ka24de-r (supercharged)
WHP:
Rods + Pistons: Cannot remember, may have been stock actually
Supercharger: I think was an eaton m62
Manifold: Modified stock for supercharger
Boost: 10-15 depending on rpm
Cams: I believe 248/248
Gas: E85
Engine: rb25det (all stock so I wasnt allowed to rev)
WHP:
Rods + Pistons: stock
Turbo: gt35
Manifold: some australian manifold
Boost: 24psi
Cams: stock
ECU: z32+ nistune
Gas: 93
Engine: rb25
WHP:
Rods + Pistons: ?
Turbo: godspeed 60-1 with small turbine housing
Manifold: ?
Boost: Cannot remember, sub 20
Cams: stock
ECU: nistune
Gas: 93
Engine: s14kadet
WHP: The low graph is the first pull, which is someone elses tune before I retuned the car.
Rods + Pistons: Forged bottom end, cannot remember compression or brand
Turbo: t25
Manifold: stock
Boost: 10-12
Cams: stock
ECU: nistune
Gas: 93
This next graph is nearly identical in setup except the engine is stock, never rebuilt. I could not get it to hold power like the other one. Ka's already do not like t25's but if one really dont like it, you wont be happy with your powerband.
Engine: s13ka24det
WHP:
Turbo: t25
Manifold: stock
Boost: 10-12
Cams: stock
Gas:
93
4x4le is offline   Reply With Quote
Old 12-26-2012, 12:40 PM   #3
4x4le
4x4le's Avatar
Oh, and I do my tuning at a diesel performance shop, so sometimes we dont remember to switch the tq and hp back on the same scale. So when looking for specific tq or hp numbers at certain rpms make sure you run to the correct side of the graph for the scale. I try to make the hp and tq scale the same when I remember to.
Also keep in mind that these are all on dyno dynamics dynos. Multiply by 1.16 for a number to compare to dynojet numbers since more people are familiar with them if your into comparing.
Old 12-27-2012, 11:32 AM   #4
[email protected]
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
Engine: S13 SR20DET
WHP: 595Whp 424ft lbs
Rods + Pistons: Wiseco .20 over, Eagle rods ( stock Sleeves )
Turbo: Precision 6266 t3 .82 ar
Manifold: Freddy Intake Manifold (unported) Stock TB
Boost: 33 [email protected]
Cams: BC 272
ECU: AEM V2 EMS
Gas: E85
Notes: Head was removed from swap and installed springs,RAS and cams thats it. same 30 year old oem valves,valve seals etc
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 12-27-2012, 10:28 PM   #5
cotbu
cotbu's Avatar
My bad 13&14psi for the dynopack run
Engine: S13 SR20DET
WHP: 289 WHP 270 WTQ 4th Gear pulls
Rods + Pistons: Oem
Turbo: GT28R w/ T-pros Exhaust Manifold
Manifold: S13sr Stock Intake Manifold
Boost: 13 Psi/14 Psi Blitz Dual-SBC Spec S
Cams: Greddy Easycam 256/264 Greddy RAS
ECU: Chipped ECU / 11.5afr
Gas: 93oct
Notes: Slipping Exedy stage 2 clutch DynoPack Dyno
Engine: S13 SR20DET
WHP: 405 WHP 357 WTQ 4th gear pull
Rods + Pistons: Oem
Turbo: GT2871r.64 56trim w/ FullRace Bottom Mnt/v44
Intake S13sr Stock Intake Manifold
Boost: 19.5 Psi Blitz Dual-SBC Spec S
ECU: Nistune / 11.3afr
Gas: 93oct
Notes: RPS Max Street PP/ ACT 6puck Sprung Disc DynoJet Dyno
Old 12-27-2012, 11:10 PM   #6
4x4le
4x4le's Avatar
Should we add what dyno these were achieved on?
Post 4 was dyno jet
post 5 top graph looks to be dynapac and bottom graph possibly looks to be dynojet or mustang?
Old 12-28-2012, 11:02 AM   #7
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
the link's say what dyno jet so I think we're good! .
Old 12-28-2012, 11:20 AM   #8
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
S13 Sr redtop,
Stock block, headgasket, and head.
850cc injectors
Emance Rom Tune
Freddy ITM
FMIC
z32 maf
adj fpr
3in o2 housing
t28 turbo
and e85 @ 15psi of boost
298 whp and about 250 ft/lb torque
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 12-29-2012, 07:36 PM   #9
Jez
Jez's Avatar
Jez is an unknown quantity at this point
S14 SR20
S14 JDM [email protected]
S15 OEM injectors
3 inch elbow back, no cat
Cone intake
FMIC
Shell 91 oct
Chipped ECU/Dyno tuned
246whp/220 ft-tq
Jez is offline   Reply With Quote
Old 01-01-2013, 10:18 PM   #10
ultimateirving
Originally Posted by Jez View Post
S14 SR20
S15 OEM injectors
Cone intake
FMIC
Shell 91 oct
246whp/220 ft-tq
GOod numbers man, nice smooth graph! and i love the low boost for good power.
Whats ur MPG like if you drive nicely?
Z32 with lq4 swap
Old 01-02-2013, 09:58 AM   #11
Jez
Jez's Avatar
With a very quick calculation I'd guess 21-22 MPG, I've never worked it out properly.
Old 03-25-2013, 11:11 AM   #12
jt1583
jt1583 is making a name for him/her selfjt1583 is making a name for him/her self
Wasn't there a google document spreadsheet for this? At least for SRs. If anyone knows of this I'd really like to see. I think I lost the link.
jt1583 is offline   Reply With Quote
Old 03-26-2013, 04:49 AM   #13
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
its at the bottom of my first link. no one seemed interested in this thread idea though. Unless someone else made another one?
Old 03-26-2013, 06:48 AM   #14
robbie2883
robbie2883 is an unknown quantity at this point
Engine: S14 S1 Rb25DET
WHP: 547 WHP 425 WTQ (ran out of fuel pump at 547 and backed it down to 501 just to keep it safe)
Rods + Pistons: Wisco Pistons & Eagle Rods
Injectors: Sard 800cc
Compression: 8-1
Turbo: Garrett GT3582R w/ 82ar Turbine housing and twin scroll manifold
Boost: 23ish Psi
Cams: OEM
ECU: Power FC w/ FC-Datalogit
Gas: 93
robbie2883 is offline   Reply With Quote
Old 03-26-2013, 03:25 PM   #15
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
^^^DAMN, figured a 3582R would make power sooner on an RB25. Didnt fully spooled on my old SR20 till 5k.
CLICK HERE!!!
Old 03-27-2013, 06:17 AM   #16
robbie2883
big turbine housing doesn't help...the lower 500whp run though we played with timing a little and if you look it's spooling alot faster (it also didn't help that the avcr was still learning boost)
Old 03-27-2013, 06:21 AM   #17
Veryflush
Veryflush's Avatar
Veryflush is an unknown quantity at this point
Engine: vg33et
WHP:
Rods + Pistons:
Stock
Boost: 20ish psi
Cams: 272
Gas: 93
Engine: s13 sr
WHP:
Rods + Pistons: ?
Turbo: 2871r
Manifold: stock
Boost: 20
Cams: stock
ECU: s13 sr nistune
Gas:93
Engine: s13 sr
WHP:
Rods + Pistons: ?
Turbo: 2871r
Manifold: greddy
Boost: 20ish
Cams: 264 I believe
ECU: s13 nistune
Gas: 93
Engine: s13 sr
WHP:
Turbo: stock
Manifold: stock
Boost: 12psi
Cams: stock
ECU: stock+ nistune
Gas: 93
Engine: NA Ka24de
Turbo: NOPE
Gas: 89
WHP:
Gas: E85
WHP:
Turbo: gt35
Boost: 24psi
Cams: stock
ECU: z32+ nistune
Gas: 93
Engine: rb25
WHP:
Rods + Pistons: ?
Manifold: ?
Cams: stock
ECU: nistune
Gas: 93
Engine: s14kadet
Turbo: t25
Manifold: stock
Boost: 10-12
Cams: stock
ECU: nistune
Gas: 93
Engine: s13ka24det
WHP:
Turbo: t25
Manifold: stock
Boost: 10-12
Cams: stock
Gas:
93
Damn I make 356whp using a gt2871r on a stock sr20det at 19psi. Something is deff wrong with those motors.
Sent from my myTouch_4G_Slide using Tapatalk 2
Veryflush is offline   Reply With Quote
Old 03-27-2013, 10:29 AM   #18
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
S13 SR20det
Rods + Pistons: CP 9:1 pistons, Eagle rods
Turbo: GT2876 .64 a/r
Injectors: Sard 850cc's
Manifold: stock+tial mv-s
Boost: 16psi
Cams: Tomie 256 poncams
ECU: AEM EMS
Gas: 92
(Clutch slip) Exedy stg2
di-devol is offline   Reply With Quote
Old 04-01-2013, 06:23 AM   #19
_kouki_monster_
_kouki_monster_ is an unknown quantity at this point
whats up with the break in the graph there at 4500rpm?
_kouki_monster_ is offline   Reply With Quote
Old 04-02-2013, 01:33 AM   #20
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
It's obviously making an infinite amount of power between 4500-4800 RPMs.
Frank_Jaeger is offline   Reply With Quote
Old 04-02-2013, 07:31 AM   #21
cotbu
cotbu's Avatar
Yeah, Sometimes the power of Nissan's can't be contained on a dyno!
Old 04-02-2013, 08:59 AM   #22
Mikester
Mikester's Avatar
Mikester is a well-known jackass
Edited for format.
Engine: Chuki S13 sr20det black top
WHP: 316 and 280.64tq
Injectors: 850CC
Compression: 8.5:1
Turbo: APEXi AX-53B70R P20 Black Label
Intake Manifold: stock
Boost: 17psi (1.15bar)
Cams: stock
ECU: Power FC
Gas: 93
Mikester is offline   Reply With Quote
Old 04-02-2013, 01:25 PM   #23
cotbu
cotbu's Avatar
Originally Posted by Mikester View Post
1994 180SX
Chuki SR black top, stock internals
- APEXi AX-53B70R P20 (Black Label) turbine
- 4" suction kit
- HKS elbow/76mm DP & 5-Zigen exhaust
- Sard 850cc injectors
- Sard regulator
- Walbro 255
- Z32 MAFS
- FMIC
- Power FC
320.3ps to the rears @1.15bar:
The lines don't cross at 5252, which is weird, but that's the sheet that Odotec Okinawa handed out at the time.
Torque conversion is 280.6 ft/lbs
Stock cams?
Oh yeah, you shouldn't have to explain why the tq & hp don't cross at 5252.Cause anyone whom can read a dyno graph knows that, if the scales are not equal on both sides they won't cross at 5252.
Old 04-02-2013, 02:23 PM   #24
Mikester
Mikester's Avatar
^^Yes, stock cams. That turbine was MUCH more fun at 1.3-1.4, but I never got it dynoed after upping the boost.
I am not an expert at reading a dyno (lol obviously). As long as the AFR's are good and the curve is smooth, I am happy
Old 04-02-2013, 02:33 PM   #25
di-devol
lol, clutch slip. Other sheets showed a loop-de loop.
Old 04-02-2013, 06:03 PM   #26
army240
army240's Avatar
army240 is an unknown quantity at this point
Sorry for the pic... took with my cell phone...
Engine: S13 SR20DET + Polished HeadPorts
WHP: 505 WHP
Dyno Sheet:
Rods + Pistons: Eagle Rod, CP Pistons 86.5mm
Injectors: SARD 850cc
Compression: 8.5:1
Turbo: Garrett GT35R .63 AR + Full Race Gen 1 (Single WG)
Manifold: Greddy Intake Manifold + Blitz Intercooler
Boost: 25 Psi
Cams: BC 272/272 + Springs & Retainers
ECU: AEM EMS v.2 (6601)
Gas: 91 + AEM Water/Meth Injection
Life is a beat to beat
army240 is offline   Reply With Quote
Old 04-02-2013, 06:50 PM   #27
jt1583
Who, not whom.
Also if the units aren't hp and lb-ft it won't be at 5252. The kgm is a wuss sounding torque unit. "An impressive 38.5 kgm you have there."
Old 04-03-2013, 08:12 AM   #28
cotbu
cotbu's Avatar
It was not a question it was a statement.
Classify "whom" as objective. It is used as the direct object of a verb or the object of a preposition. For example, "She gave the book to whom it belongs." Note that "whom" is the direct object of "gave" and is the object of the preposition "to" in the example sentence.
And the torque is more like 278.3ft/lbs, but yes impressive.
Old 04-03-2013, 09:00 AM   #29
Mikester
Mikester's Avatar
Thank you! I love that turbine; it's currently my spare~
1 kg-m = 7.23301385 ft/lbs. Therefore 38.8kg-m = 280.64 ft/lbs...
Is my math off? Not trying to split hairs.
Old 04-03-2013, 09:13 AM   #30
cotbu
cotbu's Avatar
No mines was, but it was in reference to this quote
38.5 would be 278.36
38.8 should be 280.52
just a rough estimate lol!
