Old 11-09-2008, 05:57 PM   #1
dbenavides
dbenavides is an unknown quantity at this point
Z32 Brake swap! I need Help!
I have installed Z32 calipers and rotors on my S14 and my caliper isn't sitting correctly on the rotor. The rotor is hitting the caliper and not letting the rotor turn freely. I have tried moving the rotor forward and back by adding a washing in between the caliper the upright. Has anyone had the problem before? How Can I fix this? Should I have used the Special bolts or washers to mount the Z32 calipers. Any help is appreciated!
dbenavides is offline   Reply With Quote
Old 11-09-2008, 05:59 PM   #2
dbenavides
I have tried adding different sized washers and no luck. Can anyone shine some light on this problem?
Old 11-09-2008, 06:10 PM   #3
projectRDM
projectRDM's Avatar
You should not need anything, the OE bolts and washers work fine. Sounds like you've got a mismatched set.
FORMERLY R240NA
Old 11-10-2008, 08:38 AM   #4
xcye12
xcye12 is an unknown quantity at this point
Probably, you are running 26mm calipers with 30mm rotors?
xcye12 is offline   Reply With Quote
Old 11-10-2008, 08:58 AM   #5
Ali 556
Ali 556 is a well-known jackass
+1
you have 30mm rotor and 26m caliper...you can grind the caliper to make it fit...OR you can buy/trade 26mm rotors
Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 11-10-2008, 07:44 PM   #6
dbenavides
You guys are correct I have 26mm calipers with 30mm rotors. I had a set of iron 30mm calipers sitting in my shed and I swapped them today and they bolted right up. Thanks for your help!
