Old 04-24-2016, 10:48 AM   #1
2slow2go
2slow2go's Avatar
2slow2go will become famous soon enough2slow2go will become famous soon enough2slow2go will become famous soon enough2slow2go will become famous soon enough
Sr20det swap- No Start. cranks but no fuel to spark plugs
Hi guys.
Having a bit of problem trying to get my sr20det to start. My first swap. I'm getting spark to coils and fuel pump is priming. The fuel lines are on correctly. The fuel injector plugs are pulsating. Checked my spark plugs but they are not wet after cranking. I have a wiring specialties harness.
What could be the problem?
Any help would be appreciated thanks!
2slow2go is offline   Reply With Quote
Old 04-24-2016, 11:31 AM   #2
Kingtal0n
Kingtal0n's Avatar
all an engine needs
spark fuel compression
If you see spark great.
If you notice the injectors are "pulsing" but nothing is coming out, it sounds like the fuel rail is empty (no fuel)
check fuel pressure/regulator/fuel filter
Old 04-24-2016, 02:58 PM   #3
2slow2go
2slow2go's Avatar
Turns out the fuel pump fuse blew after switch the hoses and t started.
One question. Do you use the sr20det cable throttle bracket or the ka24 one?
I don't have neither. Is there a part number for this?
Old 04-24-2016, 04:10 PM   #4
Tyler_240
Tyler_240 is an unknown quantity at this point
depends...a SOHC throttle cable will work but it stretches over the valve cover...the DOHC Throttle Cable is best
Tyler_240 is offline   Reply With Quote
Old 04-24-2016, 04:16 PM   #5
2slow2go
2slow2go's Avatar
I meant the throttle bracket to secure the cable?
