Old 07-23-2006, 12:13 PM   #1
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
Axle breaking, newly replaced, breaking again, FWD, help/thoughts?
Not a nissan, 240sx, etc.
but it's still a car, i know some of you guys out there have some mechanical experience/knowledge of this possibly
2003 Mitsubishi Eclipse 2.4L 4 cylinder
FWD
No mods.
around 200,xxx miles
*alignment is off a little, toe out? kinda like this.. | /
-axle popped off from the CV joint by the tranny making a left turn
-replaced with new one, about a month later same scenario
-replaced with new one, drove for about a mile, starting to make a left, pops out or starts to
.at idle the engine wouldn't seem to stumble much, seems normalish to me but i could be wrong, so i'm not too sure if it's the mounts
.while in gear, giving it some acceleration, it would seem to rumble (almost popping out, or in the process)
.i still have to check the mounts but most of the mounts i looked at don't seem to be in bad shape, still look pretty good but i still need to recheck
any idea on how to repair this?
i just need some other opinions if anyone has dealt with this problem or has a good idea what might be wrong with my friends FWD car
Indolent is offline   Reply With Quote
Old 07-23-2006, 01:56 PM   #2
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
Sounds like the axle is too short. make sure your putting in the correct axle.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 07-23-2006, 02:20 PM   #3
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
you have a '03 eclipse with 200k+ miles on it!??! My '90 240 doesnt have that much! How much do you drive this beast?!
undesiredshoe is offline   Reply With Quote
Old 07-23-2006, 05:16 PM   #4
Indolent
Indolent's Avatar
it's my friends, he drives it just about everyday, goes from riverside-LA a lot, thanks for the responses
Old 07-23-2006, 06:07 PM   #5
S14DB
AFC #1
S14DB's Avatar
He hit a curb and the front arms are out of spec.
