Old 07-06-2016, 10:04 PM   #1
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
97 s14 ka24de no power to ECU!!??
Hey guys, in need of some help here. Was driving along and suddenly lost power. Car cranks but no fuel pump, no spark. All accessories work, and dash lights up. Looks like the ECU isn't getting any power (no check engine light on dash, no power to the B/W wires on the back of the ECU, and no link to the OBD2 scanner)
any ideas would be appreciated, checked the obvious fuses. Not really sure which is the ECU relay, but I checked most of them.
redsx13 is offline   Reply With Quote
Old 07-13-2016, 08:08 PM   #2
redsx13
redsx13's Avatar
Solved the issue. For anyone with similar problems, the ecu relay is the blue relay located next to the ecu. This relay is operated by the ecu but is supplied a constant 12v source. The fuse which supplies power to this relay is located in the engine bay (7.5A) and labeled "EGI".
Old 07-14-2016, 09:22 AM   #3
SoundEfx
SoundEfx's Avatar
Glad you solved the issue and updated the thread for future users.
