Old 11-02-2008, 07:09 PM   #1
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection
Send a message via AIM to 1QUICK4 Send a message via MSN to 1QUICK4
Ignition Issues, won't start
I did a build on my car and I got everything put together today but the car will not start unless I jump the solenoid and the 12 volt source. Also I have an autometer cobalt boost gauge that is tied into my ignition so it doesn't lose power while cranking, and that doesn't even come on. I tested the starter wire while a friend cranked it and it only has 6 volts, car has never had a problem starting ever. Any ideas?
-383 RWHP & 407 RWTQ-
Review Thread= http://www.zilvia.net/f/showthread.php?t=201106
1QUICK4 is offline   Reply With Quote
Old 11-03-2008, 09:29 AM   #2
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
I think it may be a loose ground some where that's dropping the voltage, but I have no idea where to start. Any Help? Engine Bay ones are good but I think it might be a ground inside.
