For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
10-01-2014, 10:49 AM | #1 |
I'm selling these parts because I've upgraded to EFR t4 setup and AEM infinity. Also my living room is kinda like a garage and it would be nice have it back! Lol
(sold) EFR 6258 T25 (Turbo works fine and is used!) an oil and water lines are included,Mid boost wastegate(installed 10-20psi) and low boost wastegate(5-14psi) Ichiba v2 short runner manifold(Now has black ceramic coating) MA Motorsports Vband down pipe (has o2 bunge and crank case evac setup) Allittle about exhaust evac..http://www.carcraft.com/techarticles...uum_pump_test/ (sold) Pricing..... Turbo,manifold and downpipe $1000+shipping Turbo $800+shipping Manifold $100+shipping Down-pipe $160+shipping (Sold!) series 2 6601 This ECU fits 1991 to 1995 Nissan 180SX 2.0L Turbo 1996 to 1999 Nissan 180SX 2.0L Turbo 1991 to 1993 Nissan 240SX Swapped w/SR20 2.0L Turbo $850+shipping A video of the car running with these parts... http://youtu.be/HBZPxk6Y3OI?list=UUg...aRZdVLHVNlJrNg Here are some pictures! https://plus.google.com/photos/10253...76664619422929 $80 - z31 rear brake conversion(s14 caliper + z31 bracket and Maxima rotor) $150 - Z32 aluminum front brake caliper with 350z track rotors(can send regular rotors too) $50 Sr20det head + valve cover missing a few cam journal bolts. (No damage that i know of just need it out of my living room!) $15 each sr20det turbo elbows divided and non-divided $150 resurfaced ACT Flywheel with ACT extreme 6 puck and pressure plate Gauges! $20 each 2x Water temp $20 each 2x oil pressure $60 1x AEM true boost $65 300zx maf $100 Abaco 3.5in or 85mm 1000hp maf (Fully programmable currently has 300zx flowtable flashed.) http://www.abacoperformance.com/products.htm $25 - adjustable camber arms $25 s14 adjustable camber arms $130 Innovate MTX-L Wideband Air/Fuel Ratio Gauge http://www.innovatemotorsports.com/products/MTXL.php (Sold!)$85 Innovate LC 1 wideband w/ gauge Contact me by.... Txt - three 01 two seven 2 5 zero seven 9 Or [email protected] Last edited by konjiki7; 10-04-2014 at 01:43 PM.. |
10-01-2014, 12:23 PM | #2 |
Wished I had the money to pick up the turbo and downpipe. I also saw from the comments you mentioned that any T2 bottom mount manifold would work, and you modified yours because of the AN fitting you had on a coolant hose that made contact with the wastegate? This would have been perfect with my 1st gen F-R manifold. But would the down-pipe work with a standard manifold? GLWS. Secretly, I hope it doesn't sell so I can pick it up. Lol.
Latez, -Dave |
10-01-2014, 11:16 PM | #5 | |
Responded two seconds ago
No but it has less than 2000 miles on it. At most it may have a finger print on the glass from uninstalling it. Quote:
