Old 03-05-2008, 07:13 PM   #1
sac
sac's Avatar
sac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymore
Question s13/s14?? interchangable parts
k.. so i just got a coupe really cheap.
i was thinkin..
everyone does the brick headlight conversion and s15 conversion.
but what about a zenki conversion onto a s13 coupe..
now i havent worked on them cause its cold outside..
but wouldnt the s14 zenki fenders, hood, etc fit right on a s13 coupe?
sac is offline   Reply With Quote
Old 03-05-2008, 08:09 PM   #2
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
the holes dont line up exactly on point. they do work tho. you just drill new holes and your good to go. search for 13.4. you'll find alot of information. this site has all the information you could want you just have to search for it.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 03-09-2008, 09:29 AM   #3
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
i was thinkin..
Completely irrelevant information that should not be in the post. All this does is add useless info that confuses people.
This is completely custom work. In my life I've seen one zenki S14 front end onto an S13 swap. I myself have a kouki S14 front end swapped onto an S13.
Theoretically it should work because kouki and zenki S14 body parts are interchangeable, but you will have to get custom fenders, brackets for the core support, bumper, headlights, corner lights.
As of right now I know of no company that offers this kit. AIT and Raceone offers the kouki kit. I'm using the AIT kit.
My recommendation is to do the kouki swap if you're set on a front end, or just keep it the way it is and save your money for something else. If this is your S13 I would highly recommend waiting and see what else breaks.
g6civcx is offline   Reply With Quote
