Old 02-17-2013, 11:00 AM   #61
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Pool of oil inside trans
BiG MiKE86 is offline   Reply With Quote
Old 02-17-2013, 12:18 PM   #62
BiG MiKE86
BiG MiKE86's Avatar
-_-
Old 02-18-2013, 08:52 AM   #63
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
thats mess up!
JohanM is offline   Reply With Quote
Old 02-19-2013, 08:04 AM   #64
2muchboost
Trader Rating: (33)
Feedback Score: 33 reviews
Damn then that blows for sure. Did you figure out what was going on? I hope the same doesnt happen to me after replacing all of the seals so whatever you figure out may help me avoid any possible issues.
Thanx
Old 02-19-2013, 08:13 AM   #65
BiG MiKE86
BiG MiKE86's Avatar
Thanx
Looks like the guy who installed it pushed the seal too far in. He is giving me a new seal and I'm going to have the housing inspected for any gouges and if all looks good install the seal. Also going to reseal both oil pans while the trans is off. Ill keep u guys posted.
Old 02-26-2013, 09:06 AM   #66
2muchboost
Trader Rating: (33)
I thought that might be an issues but since the guy was Master Tech I held back from mentioning that. Yeah there is a particular depth that the seal goes into the block. If memory serves me right from the install the top of the seal should sit flush the tiny "lip" you see in the pic so that. Hope everything else is alright. Glad you figured it out.
Old 02-26-2013, 09:09 AM   #67
BiG MiKE86
BiG MiKE86's Avatar
Yeah I'm guessing one of his employees did the job because he knew the problem as soon as he saw the pics. No big deal ill be using this as an opportunity to reseal both oil pans just for safety
Old 02-27-2013, 06:58 AM   #68
2muchboost
Trader Rating: (33)
Glad you figured that out before it caused any real issues. BTW...I ended up using a dab of Gasket Maker around the Front Main Seal with the idea that it could keep the seal in place while under high boost. I was reading thru AFRACERS thread and he had done the same thing. Not sure if this is something your interested in but thought I would throw it out there just in case.
Old 03-03-2013, 09:53 AM   #69
BiG MiKE86
BiG MiKE86's Avatar
More goodies rolling in...
Old 03-04-2013, 01:55 PM   #70
atvrider647
atvrider647 is an unknown quantity at this point
I'm subbed!
atvrider647 is offline   Reply With Quote
Old 03-05-2013, 08:03 PM   #71
BiG MiKE86
BiG MiKE86's Avatar
Started installing injectors (FIC 770cc High Imp) today. Got the engine rear main seal redone as well as both oil pans resealed. If the weather is good this weekend ill be dropping her in unless something else comes up...
Old 03-05-2013, 08:14 PM   #72
BiG MiKE86
BiG MiKE86's Avatar
Some other random shots from last weekend
Marlin Crawler shifter parts (supEr tight fit) made the shifter feel soo much better. It took out tons of play.
Attachment 51544
Shifter extension
Greddy shift knob that got a new lease on life - tapped for Toyota threads
Some stuff I removed (VSV Surge tank and fuel damper)
Stock oil cooler removed
Old 03-05-2013, 09:08 PM   #73
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Nice! Thread title wins.
di-devol is offline   Reply With Quote
Old 03-06-2013, 07:27 AM   #74
2muchboost
Trader Rating: (33)
Nice progress bro...hope she drops in trouble free.
Old 03-14-2013, 09:13 PM   #75
BiG MiKE86
BiG MiKE86's Avatar
Just got these bad boys in today
Xcessive Mounts
Old 03-16-2013, 08:43 PM   #76
BiG MiKE86
BiG MiKE86's Avatar
Test fitting the nipple I made. Fits good but ill be knocking about 1/8" off on the filter side to reduce the number of turns it takes to meet the block
Old 03-16-2013, 08:45 PM   #77
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
dem mounts!
240boi115 is offline   Reply With Quote
Old 03-16-2013, 08:50 PM   #78
BiG MiKE86
BiG MiKE86's Avatar
OEM Bolt being trimmed down to make a nipple to mount the filter to the block
Old 03-17-2013, 10:19 AM   #79
di-devol
OH. That is very good!
Old 03-17-2013, 11:13 AM   #80
BiG MiKE86
BiG MiKE86's Avatar
And cheap!
Old 03-21-2013, 07:41 AM   #81
BiG MiKE86
BiG MiKE86's Avatar
More goodies Rollin in...
Old 03-21-2013, 08:38 AM   #82
2muchboost
Trader Rating: (33)
Very nice bro....when do you think she will be done?
Old 03-21-2013, 08:52 AM   #83
BiG MiKE86
BiG MiKE86's Avatar
Trying to find a few hands and some motivation to drop the engine in this weekend. After that things should go quickly
Old 03-21-2013, 05:00 PM   #84
Extreme Dimensions
Extreme Dimensions's Avatar
good job!
- Chris Gary
p: 714-278-8000 x 19
E: [email protected]
Old 04-01-2013, 08:26 AM   #85
BiG MiKE86
BiG MiKE86's Avatar
Some minor progress this weekend...
Installed turbo - had to make a "custom" tool to tighten the SHCS holding the turbo
Installed front half of turbo
Installed 2JZ-GE water pipe to remove the coolant lines going around the block
Original junk
New pipe
Side by side
Installed
It doesn't quite bolt up to the block without modification - I may slot the bracket and add a spacer for piece of mind but i doubt it's necessary
Old 04-01-2013, 08:52 AM   #86
2muchboost
Trader Rating: (33)
I was wondering what had happened to ya.....nice progress. Did you need to do any mods to the Treadstone so that the turbo lined up? I have read a few threads in which people had to modify the holes on the Treadstone and/or the turbo's to match up?
Old 04-01-2013, 08:56 AM   #87
BiG MiKE86
BiG MiKE86's Avatar
Here are some shots of the machining that had to be done on the turbo to fit the treadstone manifold
Holes slotted to slide turbo over about 2-3mm
Original fitment
Had to go with Socket Head Cap Screws due to hex heads not fitting
2-bolt to V-band wastegate adapter installed
Just modified the turbo left manifold alone
Old 04-01-2013, 07:43 PM   #88
2muchboost
Trader Rating: (33)
Thanks for the pix......I have seen a few people have to do this.
Old 04-07-2013, 04:59 PM   #89
BiG MiKE86
BiG MiKE86's Avatar
Did some work yesterday
Removed hose barb
Drilled and tapped for 1/8 NPT plug
Installed new APR flywheel bolts, flywheel, clutch & pressure plate with new hardware
Then we started dropping this monster in...
And it's in!
Shifter placement
Old 04-17-2013, 08:47 PM   #90
BiG MiKE86
BiG MiKE86's Avatar
Workin on a bracket for the A/C compressor removal. Still gotta confirm all dims and check design but here's what I've got so far... I know it's probably overkill but why not gives me a chance to play with the machines at work
The redline shows where the bracket will go
Got hooked up by a friend with some aluminum blocks to make the a/c bracket from
Started working on the Compressor Eliminator Bracket
Machined a section to the final thickness
Tomorrow ill be saw cutting the excess off then finishing remainder of machining.
Stay tuned
