Old 08-15-2020, 06:31 PM   #1
spoolinrb25det
spoolinrb25det's Avatar
spoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to behold
5 lug rotors
I'm swapping my JDM 90s Ks over to 5 lug. I believe I can use the s14 rear rotors with the stock calipers. But what about the fronts. The s14 rotors are tiny bit bigger. Will my front calipers still work?
Thanks
spoolinrb25det is offline   Reply With Quote
Old 08-15-2020, 10:13 PM   #2
spoolinrb25det
from what I can find is the jdm rotor is 250x18mm. The s14 is 252x20mm and the 86 300zx is 250x20mm. Will the 2mm difference not allow it to fit?
Old 08-16-2020, 06:56 AM   #3
S14rebuild
Just drill ur stock rotors to 5 lug ones...
Old 08-16-2020, 10:47 AM   #4
zombiewolf513
Sounds like a joke but thats legitimately an option
Old 08-16-2020, 07:42 PM   #5
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
wouldn't hurt to get a cheap rotor from a chain parts store, and throw it on to see it it'll fit. I can't imagine that 2mm would make or break it, but I've been surprised before..
If they don't fit, you can always just return the parts, no harm, no foul.
burnsauto is offline   Reply With Quote
Old 08-18-2020, 02:44 AM   #6
tromer9
tromer9 is an unknown quantity at this point
This. The best solution is to test fit.
tromer9 is offline   Reply With Quote
