10-24-2013, 12:27 AM | #3483 |
Hey guys! I've been looking through this thread from time to time and thought I should post my setup..
320whp/330tq with messed up internal wastegate. @ 5.5k it would see 18-19psi and it would start to lower around 6k and see about 15psi and would start lowering even more going to redline. Mods; Isis RS3871 (Similar to 2871r so pardon me if I shouldn't be posting in this thread) (Internal WG), Megan Racing Mani With a crappy mbc Tomei Poncams Deatschwerks 740cc Z33 Coilpacks Fuel Pump Relay R.S. Enthalpy I'm now running stock mani with external wastegate setup (38mm) Feels a lot better now and quicker. Dyno graph; Video; |
11-08-2013, 01:17 PM | #3484 |
went to te dyno today..
sr20det bc (264)stage II cams 18psi 740cc z32 maf apexi power fc the map is made by me, I need to make it richier from 2700rpms to 5000rpms, althrough the dyno wideband wasn't reading correctly... (reading leaner) |
11-08-2013, 03:41 PM | #3485 | |
Having been plagued with boost control problems, I'm now about a weekend away from dropping this bad boy back in, new and improved! |
11-09-2013, 08:42 AM | #3486 | |
Sent from my Highly Tune Galaxy S3.4!!!
LoverTechnologies "Half Broken Things!" |
11-10-2013, 01:20 AM | #3487 |
if the dyno wideband was reading leaner and it shows 11:1 on the high rpm, you can go way leaner, there's a lot of power to be unlocked in your program.
My Build |
11-11-2013, 06:57 AM | #3488 | ||
I will try this, I have about 9-10 timing on the lower cells (17-20) on the pfc about 18psi, if I put more timing, I get knock readings of 60 or higher, isn't that too low timing? |
11-11-2013, 05:42 PM | #3489 | |
Peak HP number looks good even if its a little rich but the torque number seems low. You also need to rev it out longer.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
11-11-2013, 11:06 PM | #3490 | |
if you wanna run higher ignition and be knock free, maybe its time to look into water-meth injection.
My Build |
11-12-2013, 10:05 PM | #3491 | |
Trader Rating: (58)
Feedback Score: 58 reviews
Just let me know when, shoot me a PM and we can help ya out It'll look just like the one 240ss posted
That's one of the better running ISIS setups out there. nice.
Want Air Conditioning in your SR20 Swapped car? Check out www.sr20acbrackets.com for more information! Quest Alternator Conversions for SR20! Check my Group Buy! Tired of lousy internal gates? Go external wastegate with one of my manifolds, Check out my group buy |
12-06-2013, 12:11 PM | #3492 | |
Hey Codyace, just seeing if there was any update on where you are with this?
HouseBuyers365.com Quote:
12-06-2013, 12:23 PM | #3493 |
I'm running s4's on my set up. Running 740cc injectors,apexi .8mm headgasket,intake mani,and a precision 5128 .64 ar. Same as a 2871. Set up runs smooth with an enthalpy tune,almost forgot to add that to the list. I know it pulls pretty hard in the higher Rpm's on 17lbs. Cannot say for sure where I have full spool at. Right now it is very laggy,but I am blaming that on my mbc. I should have my car back from the shop in a week or to so I'll be sure to chime in after I tune thru the internal gate,external is the way to go. Will be looking into that soon codyace!
12-09-2013, 10:08 PM | #3494 | |||
Trader Rating: (58)
And let me know when you want the manifold sorted
12-11-2013, 05:08 PM | #3495 |
more and more people with less than 400whp below 20 psi. Full spool above 15 psi around 4k. Just like mine. I am going t3 next year. I know now I will never get 400 whp on pump gas with this turbo. I am selling mine. Fuck this gt2871r
12-12-2013, 08:36 PM | #3497 | |
AFC #1
Comments should be taken as Opinions not as Statements of Fact |
12-12-2013, 09:57 PM | #3498 |
Trader Rating: (58)
If you're not taking advantage of the higher boost, it's not worthwhile (to me). If you're gonna sling 25 psi and be ok with 350psi, cool..if not...go with the tried and true disco potato.
01-22-2014, 04:06 PM | #3499 |
Finally finished reading this intire thread and had to join zilvia...
My set up is similar to codyace... vct s14 sr20det 87mm 9.1 comp pistons stock exhaust mani gtx2867,t25+ t31 .63ar turbine housing moded with tial mvs external gate nissmo 740cc, aeromotive A750, aeromotive fpr JWT S4's 5 angle valve job and a polish no porting hoping my high port intake and vct will make up for the torque loss on the higher dur. of the s4s but make some awesome numbers up top.. im building the car for road course racing/super mean street machine codyace had a chance to try out them s4's yet? |
01-22-2014, 07:29 PM | #3500 | |
2. Make sure you are using 93 octane and have 9:1 compression or less 3. Use 7-8* of ignition timing through 3000-5000rpm, and slowly add 1* per 1000 rpm so you end up around 10* at 7000rpm etc... 4. You can add a global +2* Across the board on the dyno to see how much extra torque you get back. If you gain only a tiny bit (you will always gain something) then go back down. But if you gain like 20+ then keep it and consider adding another 1-2*. Last edited by Kingtal0n; 01-28-2014 at 07:19 PM.. |
01-22-2014, 11:22 PM | #3501 |
the power fc and all the ecu's knock reading IS reliable. however, its up to the tuner to "feel" how much knock is acceptable. i was in a seminar by AEM, and the tech was tuning a t51 supra we had. this supra was tuned to 20 deg advance at 1 bar with the previous ecu. the tech started retarding the ignition, until the car was running 6 degrees. the owner , who was a tuner himself says to him what are you doing man? -but the car is knocking, the ecu says so. so they put both a phormula knock monitor and also det cans (headphones) and he says keep turning up the timing. does it knock? no. finally they got back to 20 degrees, and the car gained 150hp.
on the phormula , the guys that were using it say up to 50% is acceptable. i dont know. i wanna retune my own car with an external knock monitor cause i think the FC is overreacting. i was hitting insane knocks at 1 bar (125-150) and since i tuned it , i have max 25-35, but the car is really sluggish compared to before. i'm thinking of going water-meth to get back my missing timing...
My Build |
01-27-2014, 08:38 PM | #3502 | |
Trader Rating: (58)
Come spring time I will
01-28-2014, 05:21 PM | #3503 |
Come spring time I will [/QUOTE]
I'll have mine running in the next few weeks I'll post my numbers when I get on the dyno. Enthalpy will be tuning. If you had to put it into numbers what do you believed you gained with the extrude hone? I also have some questions about your ignition system as 400+ for spitfire coils seem a bit much... I'm a noob so still learning... Are you running more powerful coils with individual igniters and firing them with the stock igniter or how does that work.. any help would be greatly appreciated! |
01-28-2014, 05:29 PM | #3504 |
If you had to put it into numbers what do you believed you gained with the extrude hone? I also have some questions about your ignition system as 400+ for spitfire coils seem a bit much... I'm a noob so still learning...[/QUOTE] You bringing the car down here to Tampa?
01-28-2014, 05:41 PM | #3505 |
That is the plan in the future but with my schedule I'm extremely busy at the moment.. I've emailed back-and-forth with Martin a few times good help and excited to have the build going!
01-29-2014, 04:23 PM | #3506 |
Which exhaust gasket are you guys using? The OEM 7-Layer Nissan one? or the Mr Gasket copper one?
Which one is higher quality, more durable?
-Kyle |
01-29-2014, 04:28 PM | #3507 |
I have the stock 7 layer one and have removed the exhaust manifold twice and each time it reseals with out a exhaust leak.
01-29-2014, 06:36 PM | #3508 |
Trader Rating: (25)
Feedback Score: 25 reviews
exwg on stock mani now for about a month and i couldn't be more pleased
19psi all the way to redline. i highly recommend it. anyone running e85 with the 2871r? |
01-29-2014, 07:35 PM | #3510 |
Trader Rating: (25)
they just opened a station 2 miles from my house so i have been really considering it. i already have a 340 pump. thinking of some id1000s and obviously tune. how much psi are you running? i know there are alot of positive things from running e85-more timing, more boost, better temps etc. just wondering if its really worth it with this turbo.
