12-01-2015, 03:33 PM | #18871 | |
Without a heat shield, they're just squirrel shredders. |
12-02-2015, 08:42 AM | #18872 | |
I will then go with the bracket-less one. Thanks! |
12-03-2015, 07:01 AM | #18873 |
When I went in for emissions, the guy just dragged a mirror across the bottom. I have a HFC, but I'd guess a simple heat shield would satisfy the "quick glance" test, lol.
12-03-2015, 09:27 AM | #18874 | |
I think I'll go with the bracket-less one anyway. Still funny I can't seem to find a picture of one installed. |
12-03-2015, 11:20 AM | #18876 | |
Looks like those brackets were a feature requested as far back as 2004: http://zilvia.net/f/showthread.php?t=64441 I can't find installed pic either, only stock photos from ebay sales. I guess nobody tags their pics with easily searchable terms, lol. My test pipe has those little brackets. But it's been sitting on a shelf in my garage since I went with a 3" catco cat. |
12-03-2015, 11:57 AM | #18877 | |
12-04-2015, 03:59 PM | #18878 |
Recently I bought an Excessive ( version 1) throttle cable bracket, it just barley opens the throttle body even with the "position bolts" all the way back. My question is what version should I order for a s14 (1996) with s13 sr20det and greddy intake, 5spd trans if that makes a difference. Thanks in advance.
under cover brother |
12-04-2015, 04:04 PM | #18879 |
Where would be the best place to find one of these original nissan 240sx radios? (The top one, I already have the original tape deck below).
S13 Silvia Lip's f/s :www.codycasale.com
12-08-2015, 02:16 PM | #18881 |
~alternator mystery~
So my single cam habitually dies in random places, leaving me asking random people for a jump all the time. And then it dies again while i'm driving. Getting used to this shit.
Anyway, battery warning light never comes on. NEVER. And i've replaced the battery with an optima. Battery doesn't seem to be charging. Alt issue? Could it be I need to get into my dash to fix the light? Or is there some reason it's not on that's indicating my problem? |
12-08-2015, 03:32 PM | #18882 | |
12-09-2015, 11:44 PM | #18883 |
Fuel Filter Replacement
Recently got a s14 '95. Previous owner isnt sure the last time the fuel filter was replaced so I was thinking maybe it is time. I guess my questions are
1) how would you tell if the fuel filter needs to be replaced? 2) whats the recommended mileage to travel to then replace the fuel filter? 3) and, what is a good replacement? On another note, what other filters and liquids should I check/replace? I havent replaced anything since Im not sure where to start Thanks! |
12-10-2015, 07:58 AM | #18884 | |
For any new (to me) car, I plan a complete tuneup because there's no real way of knowing how the previous owner(s) maintained the car. Replace all fluids: oil, trans, diff, brake, coolant, power steering. Filters: air and fuel. Ignition: plugs, wires, cap & rotor. Inspect and grease moving parts. I'm sure someone will chime in with even more, but this should get you started. |
12-10-2015, 10:24 AM | #18885 |
Any reason the timing chain cover won't like up to be bolted back into place??? Im trying to get my car running by tonight and this is holding me back. All bolts like Up except the two in front that face downward. Thank you in advanced.
12-10-2015, 04:40 PM | #18886 |
Hey everyone!!
Anybody know if I can run two exhaust cams in the SR20DET? Can the intake gear be installed and clocked like the KA does with 2 exhaust cams?? I only ask because I bought a cam from someone thinking it was an intake (face>Palm) |
12-11-2015, 03:19 AM | #18887 | |
I changed mine to a Z32 filter, don't know if it actually helps, it is bigger then the stock S14 one... |
12-12-2015, 04:13 PM | #18889 |
don't know if this is the right place to post this or not but here it goes. I was trying to figure out if the recaro seats from an evo 8 could work in an s13.
12-12-2015, 07:51 PM | #18890 |
Yes!! It is the right place! and no, I don't believe so. Assuming you mean that can you bolt some rails to them like any other recaro and install it in a S13.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
12-13-2015, 01:39 PM | #18891 |
No, there is no reason why this should improve performance of the engine. But the filter is bigger, therefore flow in critical situations might be better. They cost the same though, so it was a no brainer for me... @Recaro-Topic: You should be able to fit them as they should be the same bolt pattern as, for example Speeds or Integra Recaros. You will however sit a bit higher then stock... Gesendet von iPhone mit Tapatalk |
12-15-2015, 11:47 AM | #18893 |
My research tells me this is a Nismo 2 way, mechanical base 2 way. Anyone can confirm?
MRP Manufacturing |
12-15-2015, 12:02 PM | #18894 |
12-15-2015, 12:48 PM | #18896 |
Hi all,
Red top SR20 in my S14. Poly engine mounts, T28, 3" elbow and 3" downpipe with no flex section. Ive got an extra 6" long, 3" diamter flex section laying around and I figured I SHOULD utilize it. It seems that If I weld in the flex halfway down the downpipe (where most manufacturers place them), it will rub on the body, I also could weld it in where the test pipe is (which would clear the body), but that seems quite far back. Any opinions here? Thanks, |
12-15-2015, 01:18 PM | #18897 |
Does anyone have an Origin Racing Line Aero for their s14?
I recently bought an s14 with that kit, and the front bumper install from the previous owner looks jank to me. Im wondering anyone can help me by answering some questions about the installation of the front bumper via PM. |
12-15-2015, 03:22 PM | #18899 |
NEW QUESTION
I have a 95 s14 with some decent steering play. I have traced it to my lower steering shaft u joint. I can see the shaft moving around inside of the u joint. I plan on replacing it but I've had no luck finding ANY part numbers or even used ones except for one ebay. The only thing i haven't done yet is call my local nissan dealership. Any one where I can get this part? AND YES I have used the search buttom. |
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
