Old 05-19-2020, 10:11 AM   #1
ilusive
ilusive is an unknown quantity at this point
SR Sr20det cranks but won't start
i have a red top sr, was running a week ago but it wouldn't idle and now it wont start.
It has spark, fuel, rechecked the timing and good compression. I'm lost at what could be the problem, the top end was recently rebuilt (it was running until recently when it decided not to start anymore)
ilusive is offline   Reply With Quote
Old 05-20-2020, 08:43 AM   #2
jedi03
what happens when you try to start it? can you upload video showing as well? checked for codes?
Old 05-20-2020, 02:19 PM   #3
ilusive
it will just crank but never actually turn over, but about a week ago it was running now it stopped. throws code 55, and for some reason it wont let me upload any videos
Old 05-20-2020, 06:51 PM   #4
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
so, upload it to youtube and post a link?
NukeKS14 is offline   Reply With Quote
Old 05-20-2020, 10:30 PM   #5
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Cas? Tps ?
Old 05-21-2020, 07:40 AM   #6
jedi03
so engine spins...do you have spark fuel air compression? also oil, gas in the tank etc?
Old 05-21-2020, 10:58 AM   #7
ilusive
cas and tps are both good
it has good compression and the link to the vid is https://www.youtube.com/watch?v=DuMhwYr_9OA
Old 05-21-2020, 11:13 AM   #8
Future240
Future240's Avatar
You have another ECU you could swap in and check?
Originally Posted by ThatGuy
Old 05-21-2020, 12:56 PM   #9
ilusive
yes but its for whenever it was a stock sr, the one on it now is tuned by martin
Old 05-28-2020, 01:57 PM   #10
ilusive
anyone have any idea of what it could be?
Old 05-28-2020, 02:21 PM   #11
S14rebuild
U say it has fuel....is that fuel pressure, or physically fuel sprayn from the injectors?
Old 05-28-2020, 02:38 PM   #12
ilusive
it has both fuel pressure and the fuel spraying from injectors
Old 05-28-2020, 04:04 PM   #13
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
cranking and turning over are the same thing.
starter engages with the flywheel, physically rotating the flywheel, which turns the rotating assembly, "turning it over".
FIRING is something else entirely.
F.A.S.T.
Fuel
Air
Spark
Timing
check those 4 and report back. you have at least 1 missing.
Old 05-29-2020, 10:34 AM   #14
jedi03
while someone is cranking w/valvecover off see if the cams spin, ground plug against intake to verify spark...
Old 05-29-2020, 11:13 AM   #15
brndck
brndck's Avatar
wait. it was running, THEN you "rebuilt the top end", THEN it wouldn't start?
or
it was running, you rebuilt the top end, it was STILL running, THEN it wouldn't start?
Old 05-29-2020, 01:17 PM   #16
ilusive
it was running, then the top got rebuilt, then it randomly stopped after I fixed the cas and put a new tps in
Old 05-29-2020, 01:23 PM   #17
Future240
Future240's Avatar
Have you checked it with another CAS or TPS? I know you said they were good, but the fact it stopped running after you changed these two variables kinda points to one of the two.
Old 05-29-2020, 01:27 PM   #18
ilusive
to be more clear, it was still running after I put the new tps on and and fixed the cas, it was out of timing, then I went to try and fix my idling issue the next day and it stopped running
so is it the cas then?
Old 05-29-2020, 02:03 PM   #19
S14rebuild
timming is still fukddd
If ur cas was bad ud have no injector pules/sparky
Old 06-02-2020, 12:43 PM   #20
jedi03
prob cas just a tooth off or close...so easy to get off
Old 06-08-2020, 01:06 PM   #21
ilusive
quick update, I replaced the spark plugs and reset the timing completely. now it seems to pop like it's about to start first time starting everytime then it'll just crank and flood the cylinders
Old 06-08-2020, 01:17 PM   #22
S14rebuild
Set mechanical timing properly then put the cas in properly...
Old 06-08-2020, 06:12 PM   #23
ilusive
yes, I set the mechanical timing properly and the cas is installed properly
Old 06-14-2020, 08:26 PM   #24
ilusive
fixed the problem, my fpr blew, just replaced the fpr and it started right up
Old 06-15-2020, 04:34 AM   #25
S14rebuild
You said you had fuel aka proper fuel pressure.....
Either or glad its running
