Old 06-11-2013, 04:36 PM   #1
95se
95se's Avatar
95se is an unknown quantity at this point
tachometer cutting out
Ok, for the last 8 years or so the tach has been cutting out. When it works it reads correctly but will just all the sudden drop to 0 and stay there for a while then all of the sudden start working again. Is this common?
z32 front brakes, spl tc rods
95se is offline   Reply With Quote
Old 06-11-2013, 05:02 PM   #2
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
im assuming by your profile name you own a zenki?
Originally Posted by 13esim View Post
I'll trade you my 300ZX and my older sister
my 240 broke down..again
240boi115 is offline   Reply With Quote
Old 06-11-2013, 05:15 PM   #3
95se
95se's Avatar
Yes, I have a '95
Old 06-11-2013, 05:21 PM   #4
240boi115
240boi115's Avatar
if its your speedo then you have a bad speed sensor if its your tach i believe there is a sensor on the rear of your diff in which might be going out on ya.
Old 06-15-2013, 04:28 PM   #5
95se
95se's Avatar
For the limited responses I take it this is not a common problem for the 240??
Old 06-16-2013, 11:30 AM   #6
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
Yea its common. Tach has probably gone bad. I just swapped another cluster in and it worked fine
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 06-18-2013, 07:17 PM   #7
Andres_G
Andres_G's Avatar
Andres_G is an unknown quantity at this point
Word. Same happen to me a couple of years ago. I simply bought another cluster and swapped out the tachometer. Works like a charm now...at least when I drive it...sigh
Andres_G is offline   Reply With Quote
Old 06-19-2013, 12:57 PM   #8
mrcooper
mrcooper is an unknown quantity at this point
easy fix, just go get a GIANT tach and stick it on your dash somewhere, like right where you need to see. then dont hook it up. just the lights so its pretty looking.. Then you.. oh wait i forgot, this is a nissan forum.. whoops.. well i guess you should just swap the cluster and do it right.
mrcooper is offline   Reply With Quote
Old 06-19-2013, 04:42 PM   #9
95se
95se's Avatar
Ok, some things that should be known about me. I don't know a lot about working on cars but I am very serious about it regardless of the limited amount of mods I have or it not being a high dollar car. I realize it has potential and most of these cars have been beat up on. I know some of my posts are very anal and maybe simple but thats just me trying to get good full answers. I am not into taking the cheap stitch it together I guess you say type of route just want to fix things right.
Old 06-19-2013, 04:49 PM   #10
Andres_G
Andres_G's Avatar
I think that guy was being sarcastic...there seems to be alot of that going on around here. If you want good answers when it comes to these types of problems, you should head over to NICO forums. Most of the people there tend not to act like assholes. Unless you have micro-soldering skills and have the schematics for that tach gauge...I suggest you get an aftermarket tach, or buy a cluster and take the tach out.
Old 06-19-2013, 05:30 PM   #11
95se
95se's Avatar
How much does does the cluster usually run? I have an se with the white gauges. I assume what u mean by the cluster is the gauges (speedo, tach, temp and gas) ? I thought it would be a sensor problem and the sensor would be located somewhere else and not in the actual gauge itself. I almost think its a grounding issue. When my amp isnt hooked up to the battery it seems to happen much less. I know that sounds wierd.
