Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 12-05-2012, 05:36 AM   #91
TwoFrotty
TwoFrotty's Avatar
TwoFrotty is an unknown quantity at this point
What's the chances you still have some of these?
Drifting isn't a Sport... It's a way of Life!
TwoFrotty is offline   Reply With Quote
Old 01-04-2013, 11:17 PM   #92
nidr0x
nidr0x is an unknown quantity at this point
nidr0x is offline   Reply With Quote
Old 01-05-2013, 06:39 AM   #93
EvoVIII808
Originally Posted by nidr0x View Post
Hi,
Its correct to install the adaptor in passenger side with the included gold spacer and in the driver side install a gold 7mm spacer? Its ok? Thanks!
yes. you may run into some issues with Toe corrections. I ran out of threads on my stock S13 tie rods. so i ran the big spacer without the small 7mm.
Check Out My S13 Build
Old 01-07-2013, 07:34 PM   #94
nidr0x
Thanks, in this case i install only the steering angle adaptor.
Old 01-11-2013, 11:07 AM   #95
nidr0x
I tried to install with the oem tie rods and track rods and its impossible to centre the two wheels in my case.
I tried to remove the spacer from the adaptor and same result. If i install aftermarket track rods and tie rods the problem continues? Thanks
Old 01-11-2013, 07:53 PM   #96
EvoVIII808
Had no problems with my stock s13 rods. I just had to take off the 7mm spacer. Im not sure it will work correctly with longer rods, unless you have more threads for adjustment. Try recentering you rack again.
Old 01-11-2013, 08:25 PM   #97
240SilviaX
240SilviaX's Avatar
240SilviaX is an unknown quantity at this point
If your car has too much toe in after the adapter install and have adjusted the inner and outer tie rods to the max,, (bottoming out the inner into the outer) if you have more threads on the inner just cut about 1/2-1" of the threads off the end of the inner tie rod that threads into to the outer and wham more toe out adjust-ability
240SilviaX is offline   Reply With Quote
Old 05-20-2013, 03:50 PM   #98
uaserge
uaserge is an unknown quantity at this point
You still got this???
uaserge is offline   Reply With Quote
Old 06-02-2013, 04:10 PM   #99
artica
artica is an unknown quantity at this point
I cut off a few mm's of thread from my passenger tie rod and it was the best idea ever!!!
I also used a Tap and Die kit to make the threads go in longer on the tie rod.
Then I backed out the die to make sure the tie rod end still has a good starting thread to work into the outer joint.
full adjustability now.
artica is offline   Reply With Quote
Old 10-01-2013, 10:53 AM   #100
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
This is the cheapest way to get more angle!!! Backwards entry time....
Godspeed Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988
W:godspeedproject.com
www.facebook.com/godspeedproject
Fatboy Garage is offline   Reply With Quote
Old 10-10-2013, 12:20 PM   #101
Fatboy Garage
Thread updated! Going to be uploading a video soon on how to recenter a steering rack!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 10-14-2013, 12:49 PM   #102
Fatboy Garage
Columbus day bump!!!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 10-22-2013, 01:41 PM   #103
Fatboy Garage
steering angle adapters in stock and ready to go!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-04-2013, 11:39 AM   #104
Fatboy Garage
Steering Angle Adapters! Cheapest way to get more angle out of your S-Chassis!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-22-2013, 04:31 PM   #105
Fatboy Garage
These adapters in stock and always ready to go.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
