Old 09-22-2015, 01:49 PM   #1111
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Quick question for you wiring gurus...
The EGI fuse on the S14, is that used for the fuel pump? If so, can I interrupt this line and use it as the trigger for an upgraded relay and wiring for my fuel pump?
Also, I have a Blue Sea systems 12 gang fuse block that is rated at 32VDC, 30A per circuit, 125A total. Circuits that I will be using on the block are:
IGN - 30A
P WINDOW - 25A
RH LAMP - 20A
LH LAMP - 20A
AUDIO - 15A
ALT S. - 7.5A
EGI - 7.5A
Oddly enough, the circuits that I chose to keep in the car total to exactly 125A (which is the max capacity for the fuse block).
Common sense would assume that these circuits wouldn't always be pulling these amperage values, so there should be wiggle room to add more circuits...
Do you think it's SAFE to add another 30A fuse for my radiator fans and a 10-15A for my oil cooler?
I'm leaning towards no, but I want to get input from people that have done this before. Thanks!
EDIT: Does the ALT S. wire absolutely have to go to the battery side or can I leave it on the fuse block after the breaker?
Old 09-22-2015, 04:07 PM   #1112
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Don't want to try and spend anymore money but I'm wondering if I should just buy a block like this and do the entire setup on this one block:
4 Circuit (Higher AMP components)
IGN - 30A MIDI/AMI Fuse
RAD FAN - 30A MIDI/AMI Fuse
45A FL - 40A MIDI/AMI Fuse
75A FL - 70A MIDI/AMI Fuse
6 Circuit (Lower AMP components)
P WINDOW - 25A
RH LAMP - 20A
LH LAMP - 20A
AUDIO - 15A
ALT S. - 7.5A
EGI - 7.5A
This is all well in theory, however, this setup still requires me to find a place to add a 15A fuse for my oil cooler fan. I just want to do this as cleanly and safe as possible. If anyone has any completely different ideas, please chime in. I am definitely no wiring master and can use all the help I can get.
Old 10-15-2015, 03:10 AM   #1113
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
who does wiring jobs in socal?
NEED Bolt kits for your car?
Old 10-17-2015, 01:19 AM   #1114
ehhhregartless
www.zeedakay.com
IG: @zeedakay
Old 12-14-2015, 11:55 AM   #1115
FM_Chenzy
FM_Chenzy is an unknown quantity at this point
I've been dealing with wiring problems for a while now, i got to the point where i want to make my own body harness. I just have a couple of quick questions for you gurus.
I have a 96 s14, and i want to know if you guys knew of anything that needs to be in the body harness for car to work?
Second question is how hard is it to wire your cluster in?
What relays/fuse holders do you recommend?
FM_Chenzy is offline   Reply With Quote
Old 12-17-2015, 05:33 AM   #1116
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Anyone in here ever go with a pre made Hoitsma chassis harness?
corkscrew is offline   Reply With Quote
Old 12-17-2015, 07:15 AM   #1117
Bleakley
Bleakley is an unknown quantity at this point
Ask yuri at wiring specialties if he'll custom make you one. I'd be interested to see if he would.
If he could start doing chassis harnesses I would flip f***ing sh!t..
Bleakley is offline   Reply With Quote
Old 12-17-2015, 08:33 AM   #1118
240boosted
240boosted has a little shameless behavior in the past
Tucked and loomed Mil-spec harnesses is what I do lol.
My Mil-spec RB25 setup from the JefeS14, currently for sale with harness:
Conrad Grunewald's Mil-spec LSA harness in his 2010 Formula D Camaro, from scratch.
that nice and clean wow
240boosted is offline   Reply With Quote
Old 12-17-2015, 11:47 AM   #1119
onehundredoctane
onehundredoctane's Avatar
Good God. . . quoting posts from 2010? Did you just get the internet today. . . ?
Old 12-19-2015, 10:38 AM   #1120
Smooth
Smooth's Avatar
Smooth is an unknown quantity at this point
95% complete! just need to route and connect the reverse and speedo wires.
Smooth is offline   Reply With Quote
Old 12-20-2015, 04:46 PM   #1121
corkscrew
corkscrew's Avatar
He said the tucked engine bay harness is in the works for summer 2016
Old 02-15-2016, 07:18 PM   #1122
KAT-PWR
KAT-PWR's Avatar
Majority of the tuck summed up. At least chassis harness wise. Need to clean up the engine harness next
MRP Manufacturing
Old 02-16-2016, 07:05 PM   #1123
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Nice. That's clean.
Old 03-02-2016, 11:13 PM   #1124
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Rusty radiator crushed air filter epoxied maf sputnik o2 sensors 0/10.
Frank_Jaeger is offline   Reply With Quote
Old 03-04-2016, 02:26 PM   #1125
Mister.E
Mister.E's Avatar
Trader Rating: (53)
They were prototyping chassis harnesses back in September '15. I'm not sure how much progress has been made though.
On another note, for anyone that has rewired the engine bay/fuse box harness in their S14, what have you guys done with the SMJ? I want to use all new wire, but I have not found an SMJ or pin kit anywhere. Just a pin kit would be great, if it even exists. Are people just cutting the factory wiring into pig tails and then soldering to the new wiring?
Old 03-09-2016, 03:46 PM   #1126
KAT-PWR
KAT-PWR's Avatar
Still plugging along
MRP Manufacturing
Old 03-19-2016, 07:38 AM   #1127
ehhhregartless
www.zeedakay.com
IG: @zeedakay
Old 03-20-2016, 03:01 PM   #1128
NotLowEnough
NotLowEnough is an unknown quantity at this point
Almost done....
NotLowEnough is offline   Reply With Quote
Old 05-23-2016, 12:33 PM   #1129
gerson408
gerson408's Avatar
gerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymore
Revive
Revive +1 lol anyone?
gerson408 is offline   Reply With Quote
Old 05-25-2016, 12:21 PM   #1130
corby_baby
corby_baby is an unknown quantity at this point
http://zilvia.net/f/showthread.php?t=488537&page=12
corby_baby is offline   Reply With Quote
Old 06-04-2016, 08:08 PM   #1131
ehhhregartless
www.zeedakay.com
IG: @zeedakay
Old 07-19-2016, 06:41 AM   #1132
RB25GUY
RB25GUY's Avatar
My dude starting up a harness for our buddies k miata
the bay now as is sits....
Old 07-19-2016, 07:42 AM   #1133
TheRealSy90
TheRealSy90's Avatar
In my 89 S13 I tucked the engine bay harness with both the fuse and relay boxes under the dash and the only wires I cut and extended was to the headlights. Pretty simple when there's not climate controls or ducting under there
Such a good signature.
Old 09-30-2016, 03:17 PM   #1134
shaggy sr
shaggy sr's Avatar
shaggy sr is an unknown quantity at this point
Originally Posted by NotLowEnough View Post
Almost done....
wow looks dope! more current photos?
shaggy sr is offline   Reply With Quote
Old 10-04-2016, 09:53 AM   #1135
NotLowEnough
Most recent picture I have
Old 10-18-2016, 07:57 AM   #1136
zachvirus
zachvirus is an unknown quantity at this point
My current build.
Everything connected.
Fuse box is behind radio and climate control
zachvirus is offline   Reply With Quote
Old 03-05-2017, 01:27 AM   #1137
EarlsWorld
EarlsWorld's Avatar
EarlsWorld is on the path to ruinEarlsWorld is on the path to ruinEarlsWorld is on the path to ruin
Originally Posted by ctnewman View Post
Pretty tucked:
where is your exhaust headed to? interesting setup
How cool is being cool?
EarlsWorld is offline   Reply With Quote
Old 03-05-2017, 07:56 AM   #1138
JM216S14
JM216S14's Avatar
JM216S14 is on a distinguished road
Did you shorten the entire engine at harness or just tie it up under the dash? I'm debating on what to do with mine shorten it which is a lot of pissing around or just tieing it up...
JM216S14 is offline   Reply With Quote
Old 04-20-2017, 02:16 PM   #1139
dwnshft2drft
dwnshft2drft's Avatar
Trader Rating: (28)
dwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enough
Feedback Score: 28 reviews
No cup holder and now this... lol
dwnshft2drft is offline   Reply With Quote
Old 04-21-2017, 09:44 PM   #1140
zachvirus
I relocated my fuse box to behind the center vents on the dash, just above the climate control and radio. Just pop out the vent and boom all my fuses.
Sent from my SM-N920T using Tapatalk
