Old 07-05-2013, 06:13 AM   #1
R3cK
R3cK is an unknown quantity at this point
Question Innovate MTX-L question/issue
Wired and calibrated my MTX-L
worked fine while not driving and playing with the throttle.
then i drove only some feet and suddenly it shows the E2 code again
E2 means no sensor detected like when you have to calibrate it.
any ideas?
i read about people got the same issue and even replaced the sensor but had the same problem after that.
no solution so far..
R3cK is offline   Reply With Quote
Old 07-06-2013, 12:57 PM   #2
tobroketobuildarealcar
tobroketobuildarealcar is an unknown quantity at this point
Make shure you have a good ground for the electrical circut
I have seen so many odball problems happen bc of a bad ground
tobroketobuildarealcar is offline   Reply With Quote
code e2, innovate, mtx-l
