For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Join Date: Sep 2006
FS: RSR Exhaust S13, 550cc Injectors, Apexi ECV, Grounding Kit, SR Parts
It's that time again. Time to clean up and get rid of all the leftover from a rebuild. FREE SHIPPING on all items unless otherwise noted
![]() Apexi ECV 80mm - SOLD - Everything is in good condition. The end of the line is frayed a bit from dragging, but that can be fixed easily. RSR ExMag Exhaust 80mm for S13 (first version with black coating) - SOLD- PICK UP ONLY - Used but in good condition. There are scratches at the bottom of the piping, but no dents no holes and no rust. Tip is in great condition, just need a little polishing. S13 SR20DET Fuel Rail with 550cc Subaru STI injectors - SOLD - These were brand new from Subaru. Used for about a year. Same tuning like Nismo/Tomei injectors. Apexi Versa Cruise Grounding Kit - SOLD - Got it a couple of years ago from Apexi. Comes with two 2 long and 1 short wires. Works great. S13 SR20DET Upper Oil Pan - SOLD - Long story short, it has a crack at the bottom. ARP made the SR main studs too long so it was hitting against the upper pan. Nothing JB weld can't fix ![]() S13 SR20DET Stock Oil Catchcan - SOLD S13 SR20DET Water Pump - SOLD - Used for about 10K miles S13 SR20DET IACV - SOLD - Taken off at 72k miles. Still works before taken off. S13 SR20DET Cam Gears - $50 Shipped - Both intake and exhaust cam gears. Great condition. S13 SR20DET Oil Pump - SOLD - Taken off at 72k miles. Still works before taken off. S13 SR20DET Used Timing Chain Kit - SOLD- Taken off at 72k miles. Was completely replaced by a brand new kit. Even comes with the top timing guide and oil pump gear. S13 SR20DET Lower Oil Pan - SOLD - A little dent, but that can be tapped out. S13 SR20DET Head Bolts - SOLD - Great condition. S14 240SX Rear Camber Arms - SOLD - Still in good condition. Last edited by koukie180; 02-22-2012 at 09:54 AM.. |
Really? can you give me a link? Mine is the first version with black coating, here is the second version w/o coating.
RSR 12-N010S ExMag Exhaust Magic 80mm Turbo Catback System Nissan S13 |
