Old 02-06-2010, 04:51 PM   #1
icapture
icapture is an unknown quantity at this point
Stock SR - need new MAFS - SR MAFS or Z32 MAFS?
I installed a SR into a S30 Datsun recently and rev's wont go over 3k without bogging out. Idles perfectly, but give it some gas (+3000k) and she starts to bog.
My question. I see a bunch of guys swear by the increased flow of the Z32 MAF sensor but I am wondering if that is needed when running a stock SR set up. I am planning on playing with boost a little, but not going more than 13-14 lbs.
Anyway, should I upgrade to the Z32 or stay stock with a new SR MAF sensor?
icapture is offline   Reply With Quote
Old 02-06-2010, 05:03 PM   #2
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
or you could just get an SOHC (KA24E) MAFS
Propaganda is offline   Reply With Quote
Old 02-06-2010, 06:51 PM   #3
drift_maniac
drift_maniac is an unknown quantity at this point
maybe your MAF is bad. try the DOHC or even the SOHC MAF.
im not sure if its a good idea to use a Z32 MAF with stock injectors, but correct me if im wrong.
drift_maniac is offline   Reply With Quote
Old 02-06-2010, 07:12 PM   #4
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
dont you need some type of controller when switching mafs?
reccakun08 is offline   Reply With Quote
Old 02-06-2010, 07:17 PM   #5
drift_maniac
your not talking about the air/fuel ratio gauge are you?.. i dont recall needing a 'controller' when switching match.
Old 02-06-2010, 07:18 PM   #6
Sileighty_85
Sileighty_85's Avatar
DOHC KA MAFS wont work only SOHC will work but ONLY with the R/T SR
If its an S14 SR then you need to either get the correct year MAFS for the Engine or an SAFC and N60 or N62 MAFS
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-06-2010, 08:25 PM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Z maf sends a different voltage signal to the stock ECU. You need atleast a SAFC to correct the voltage input so the ECU wont go haywire with it on or an ECU rom tune.
Did you already tried to clean the MAF element with an electrical contact cleaner? Also, double check the MAF wiring.
CLICK HERE!!!
Old 02-06-2010, 08:57 PM   #8
drift_maniac
shit silly me
thanks buddy =]
Old 02-07-2010, 09:59 AM   #9
reccakun08
reccakun08's Avatar
more like an air fuel controller not gauge.
haha thank you flip for clarifying.
to OP they do sell maf air flow sensor cleaners at local autopart store. i think its made by crc too.
