Old 05-31-2010, 10:17 AM   #1
kassed33
kassed33 is an unknown quantity at this point
SR How long should my Kaaz 2way last as DD?
I have a S14 with a Kaaz 2way in it. I have had it for prob about 5yrs and put only about 10,000 miles on it. Mostly DD, a few times at the drag strip, and a few autocross events. It is starting to make a weird noise when i make slight right turns kinda like a clicking/grinding noise. Its not the wheel bearing i checked that and there are no loose suspension parts. I changed the diff fluid just after i broke it in but not since then since i only really drive it in the spring and summer months. So i was wondering if anyone know about how long they last as a DD that isnt really driven very hard very often.
josh kassed
kassed33 is offline   Reply With Quote
Old 05-31-2010, 12:29 PM   #2
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
They should last forever if you keep up with maintenance.
g6civcx is offline   Reply With Quote
Old 05-31-2010, 12:34 PM   #3
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
I think you have to change the fluid pretty regularly? Try changing the fluid.
Old 05-31-2010, 12:43 PM   #4
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
i change fluids after events and/or every other oil change
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
