10-06-2010, 09:10 PM | #3003 |
sr is going to be the cheapest way rb is going to be more expensive but give you more reliability IMO
my car burns gas and rubber thats a real hybrid |
10-06-2010, 09:57 PM | #3004 | |
Get the SR
-Brandon |
10-07-2010, 01:53 AM | #3005 |
looked all over, not sure where to find the answer...
how many MM effectively does an 18x10.5 +15 sit farther out than an 18x9.5 +15? Is it as simple as 1/2" or ~13mm or is there a way to calculate this? Trying to figure out what size spacer to run in the rear of my Kouki...18x9.5 +15...I'm thinking a 15mm spacer but i don't want ridiculous poke, just flush |
10-07-2010, 03:54 AM | #3006 |
Great thread!
Should I buy this car and besides rust what else should I look for? Car: 1991 Nissan 240SX |
10-07-2010, 06:07 AM | #3008 | |
Im running 18x9.5 +22, no spacer, 255/40 tire with just a roll. I could probably get a 5mm slip on in there, but Im not looking for a super aggressive setup. |
10-07-2010, 07:49 AM | #3009 | |
I want a boost controller and i imagine boosting like...10-11psi? Do i need single or dual solenoid? does it matter?
http://www.1010tires.com/WheelOffsetCalculator.asp |
10-07-2010, 08:32 AM | #3010 | |
-Brandon |
10-07-2010, 01:09 PM | #3011 |
has anyone bought a full set of varrstoen 18x10.5 0 offset? if so, can you post fitment on a stock body s14? I don't mind rolling the fenders because I am trying not to go widebody.
what size tires? i was thinking of running 225/40 all around
10-07-2010, 01:21 PM | #3012 |
hey i need help ! i switch my stock cluster for the jdm on my 90.s13 but i need to know witch wires to repin to make the od/spd and temp gauge work ? anything o help !!
10-07-2010, 01:23 PM | #3013 | |
only person i know of that has bought the 18x10.5+0 is a friend with a r32 skyline =\ but i'm at 10.5J+14 so, u can CERTAINLY make up for the +14 mm through tire size and slight camber. Im using 235/40-18 fattyerals. if u used 225/40, u'd probably only need a 8-10mm more roll/pull, which is not too bad... |
10-07-2010, 02:40 PM | #3014 | |
10-07-2010, 04:29 PM | #3015 |
I want to get 17x9 +0 and 17x10 +0 and want to get over fenders but im not sure if what i have in mind is to much.
I want 30mm front 50mm back will it be to much for it or should i go less also a beefy tire is a must in the back. What would be a good combo for the wheel sizes i want? It will be my dd/track car and love the wide stance on it. Someone help me out please.
s14 grip monster=2011-2012 |
10-07-2010, 04:55 PM | #3016 |
10-07-2010, 05:54 PM | #3017 |
I been looking all over for s13 1989-90 passenger side fender localy and cant find none. what i wanted to know is if i use a 1991-93 fender would it fit decent without a front bumper? Or would it not even be worth it, and i should just wait til i find a 1989-90 fender?
10-07-2010, 06:34 PM | #3018 |
Is the bumper here at the bottom (the K's aero bumper) a true legit bumper or is it some wannabe knock off?
MyNismo.com - NISSAN JDM S13 Silvia Conversion
Driftphreak87 |
10-08-2010, 03:21 AM | #3019 | ||
10-08-2010, 07:22 AM | #3021 | |
10-08-2010, 07:42 AM | #3022 | |
10-08-2010, 10:58 AM | #3023 | |
10-08-2010, 12:02 PM | #3024 | |
Car isnt very low, but I have plenty of clearance now that the fenders are rolled. 18x9.5 +22 all around, 235/40 up front, 255/35 rear. The third picture is a 225/40 front. I thought it looked goofy, and after smashing one of my wheels on a pothole, I went to 235/40 and am much happier. The 225 looks AWESOME on a 9.5 wheel, but the car needed to be lower for it to look good. Super low, super aggressive stance was never my goal, and seeing as this is a daily driven street car, I care more about protecting my wheels than anything else. Plus the ride is much better with the 235 fronts. It doesnt seem like a big difference (10mm), but theres a LOT more sidewall available now. And yes, I know.. None of my body panels match. Edit.. the third picture is also a 255/40 rear, (first and second pics are a 255/35) |
10-08-2010, 12:56 PM | #3025 |
Stupid question: i want to put the 17 inch rims on my S14. I would like to have 9/9.5 front and 10/10.5 on the rear, without have too much camber and roll the fender. What is the right ET? I want a FLUSH style, not HELLAFLUSH!
七転び八起き |
10-08-2010, 01:09 PM | #3028 |
There is no "right or wrong" ET.. Its one of several factors you need to consider when purchasing wheels. You could go with a very low offset for a more aggressive look, but that would limit your tire options. Or you could go with a more mild offset, so you have the option of running some more rubber under there. Until you understand WHAT offset is and how it works, any wheel buying will simply be guesswork. Check this guy out: Wheel Offset Calculator
10-08-2010, 03:10 PM | #3030 | |
different between two wheels with the same offset is half an inch. offset is measured by the mounting point compared to the middle of the rim. if the rim is an inch wider, that would leave half an inch on each side of the mounting point....if that at all makes sense...it does in my head....should be right. |
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
