Old 08-30-2014, 04:28 AM   #1
s13q
s13q is an unknown quantity at this point
Can S13 crossmembers shift side to side? One of my wheels are sticking out
Urgh, got an annoying problem.
One wheel looks like its got a spacer on it, sticks out further out.
I changed the LCAs and no difference. I checked the steering arms, coils, caster and all is fine.
Some alignment guy told me he needs to "adjust the crossmember" and knock it a bit to the other side to even things out.
Any ideas?
s13q is offline   Reply With Quote
Old 08-30-2014, 08:12 AM   #2
Moore
Moore is an unknown quantity at this point
The cross member just line's up to studs. There's clearance but not enough to make a noticeable look like one side would have a spacer on. Car ever been in an accident?
Moore is offline   Reply With Quote
Old 08-30-2014, 08:30 AM   #3
Bleakley
Bleakley is an unknown quantity at this point
Front or Rear? Pictures?
Offset/size of rims different?
Bleakley is offline   Reply With Quote
Old 08-30-2014, 10:09 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
S13s are notorious for that. Could have been wrecked before and frame is tweaked.
CLICK HERE!!!
Old 08-30-2014, 10:14 AM   #5
driftminds13
driftminds13 is an unknown quantity at this point
Also, if your chassis harness (under driver fender) has been relocated up more to accommodate big wheels/tires and lowness your fender will bulge out more than the pass side making it look like one wheel is sunken in more.
Could also be a tweak in the front end like ^he said.
driftminds13 is offline   Reply With Quote
Old 08-30-2014, 10:51 AM   #6
Signition
Signition is an unknown quantity at this point
Exactly what happened to my fenders when i tucked the harness up.
Signition is offline   Reply With Quote
Old 08-31-2014, 06:59 AM   #7
s13q
Hey guys.
I did have a minor accident and I think you guys are right!
The front of the guard was hit so I think its been kinked in making the wheel more sunken in.
Its weird I never noticed until you guys mentioned it. I have a spare guard at home that needs painting but man those fenders are sooo flimsy lol.
Thanks for your input lads!
Old 08-31-2014, 09:48 AM   #8
gazingelec
gazingelec is an unknown quantity at this point
good info,S13s are notorious for that. Could have been wrecked before and frame is tweaked.thanks
gazingelec is offline   Reply With Quote
