Old 06-11-2014, 06:42 PM   #1
Jon_Rodriguez
Jon_Rodriguez is an unknown quantity at this point
VH45DE S13 build.
Hey guys, I will be posting my progression with my VH45de into a S13 Coupe.
Out with the SR20! Time to spruce up the engine bay.
Got this VH45 from LKQ only 136k on it!
Grabbed a Intake manifold off ebay for 90 bucks. Seems to be looking good. (:
I'm going with the Z32 TT tranny. It surprised me that it came with a starter,Slave cylinder, and the fork!
97 Q45 Wiring harness, came with ECU. I'm waiting for my KA harness.
97 Q45 ECU, I'm going to install a daughterboard for it later on!
Xcessive Transmission adaptor. I read good reviews on it. I'm going with the rest of their kits for the swap.
This is all i saved for right now. I'm going to be updating the thread with sanding/wiring work in the next 2-3 weeks!
Jon_Rodriguez is offline   Reply With Quote
Old 06-13-2014, 11:59 AM   #2
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
Excited for progress on another VH swap!
@s13cole
FourtyKid is offline   Reply With Quote
Old 06-13-2014, 07:21 PM   #3
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
Have you checked to see if a 97 Q45 (Y33) ECU can work with a 90-95 (G50) VH45?
Y33's came with VH41DE.
90-95 VH45's can be controlled by the same ECU but the harness is different at the ignitors, 96 is different (OBDII no VVT etc), and 97+ is a completely different car/setup. May want to double check that before you get balls deep in the swap and they aren't compatible.
The xcessive setup is a solid setup. The only thing I dreaded was grinding the crank for the flywheel spacer. Mazworx headers also work with xcessive mounts and you can save a good amount ordering them uncoated and taking care of that yourself.
niscur29 is offline   Reply With Quote
