![]() Join Date: Jan 2008
Introducing NEO Motorsport Suspension - Track Tested & Proven ! Many Applications !
Introducing NEO Motorsport Suspension to the USA. NEO TRACK Coilover kit was engineered for improved handling both on and off the track. The shortened shell case allows for maximum piston stroke, which translates to a better ride at lower ride height and an increase in grip. The NEO Green systems are also equipped with a pillow ball upper mount. The pillow ball upper mount offers an increase in steering feel as well as upper camber adjustment for strut type vehicles. Having been in the racing community for 10 years we have run just about everything the market has had and currently has to offer. We have been using the Neo Motorsport suspension for the 2012 Drift Season and have been very very pleased with the results. The NEO Coils have helped us to achieve many podium finishes and victories for the 2012 Season ! Driver Feedback on these coilovers : “The suspension travel for being a track coilover is superior to just about every “track” suspension kit I have ever used, most of them are too rigid and either you skip along the track or the car is too bouncy. These provide far more stability and the squat needed for traction.” The Neo Motorsports Track Coilover Attributes : - Steel Damper Construction - Twin Tube Design - Dampening Adjustable - 30mm Shock Piston - Shortened Shock Body for Lowered Ride height - Ride height Adjustable via lower mount - Camber Adjustable via Front Upper Mount - Patented Upper Spring Bearing Assembly (No More Spring Collar issues, upper bearing allows the shock to Steer Freely of applying stress to the spring collars). - FORGED Aluminum Shock Mounts - Fully Rebuildable - 1 Year Manufacturer Warranty Variable Spring Rates are available upon request. ![]() ![]() There are many available applications. Please let us know which vehicle you are working on and where you are located. Ex : Price for Nissan S14 – Ship to Atlanta, GA ? Thank you.
Contact: Phone - 513-874-2508 AIM - ZLR0bert Email - [email protected] Zerolift facebook - http://www.facebook.com/Zerolift Last edited by Zerolift Autolab; 10-02-2012 at 04:23 PM.. Reason: add info |
S13 shipped to 90605 Whittier, Ca
Can these be picked up anywhere as an alternative to paying shipping? Sent from my T-Mobile myTouch 3G Slide using Tapatalk 2 |
PM's SENT TO ALL OF THE ABOVE ^
KEEP THE REQUESTS COMING THANKS!
Contact: Phone - 513-874-2508 AIM - ZLR0bert Email - [email protected] Zerolift facebook - http://www.facebook.com/Zerolift |
Yes they can be fitted with Z32 Rear Mounts no problem.
Pms sent! ^
ALL S Chassis Coilovers in stock ! Thanks for the PM.
#19 |
^ PM's SENT
