08-22-2008, 07:06 PM | #61 |
Well guys, im done, mostly.
Well everything is in and torqed down. Things went pretty smoothly consdiering I'm just now getting into cars.
Now I need to get some wheels, im thinking some oldschool meshi's but I dont know, I have a really low price range, as in 800 needs to get me wheels and tires. Let me know if you have any ideas or wheels for sale. Here are my fucked up wheels, both on the driver side, one is bent for sure the other just has rash. Rear Driver Side Front Driver Side (bent)
08-25-2008, 05:45 PM | #64 |
for under 800 you can easily find some old school meshies in the for sale section and good job on the repairs. when my friends work on their shit they drive me crazy with their shitty slow ass work......
08-25-2008, 05:49 PM | #65 |
oh heres some but they won't ship, i can pick em up for you and ship em if u want lol
http://zilvia.net/f/wheels-tires/209...res-350-a.html |
09-12-2008, 01:04 PM | #66 |
All finished!
Got my new wheels today. Decided against the meshi's though. I like the wheels I chose, they are the Hanbai DT-05r's and they should last me until I go 5lug. Check um out and tell me what you think! Not bad considering im poor...
09-12-2008, 10:20 PM | #67 |
Nice job bro! Congrats on getting it all done. I really like those wheels btw, seems like a good find to me.
www.tannermunsondrifting.com |
09-12-2008, 11:18 PM | #68 |
Update! Big problem!!!
Ok so, I put the wheels on, went to les schwab and got an alignment then went for a drive. The car drifts to the left then when you try to correct it to go straight the steering wheel veers to the right. I cant seem to get the damn thing to go straight, its sooooooooooooooo annoying to have to go back and forth and drive with 2 fucking hands!!!
ANY IDEAS on what the problem is? The rack is now longer "power" I filled it with power steering fluid but it doesnt seem to work. Is my rack broken in such a way that it wont steer right? Its the only thing I can think of besides the possibility that they didnt ACTUALLY align my car.... I'm afraid to drive on the freeway with this thing, you have to keep your guard up! so any responses would be gladly appreciated!!!!!
09-13-2008, 08:30 AM | #70 |
So do you think the leaky rack would cause steering problems such as the ones im having? I mean its very possible there is more then just a leak, I mean, I did snap the tie rod so I wouldnt be suprised if there is something else wrong with it.
It sucks cause im out of money for a few weeks, blahh! I'm not sure if I even want to try driving it.... I asked the guy at les schwab about a replacement rack and they said they dont carry "that type" of rack there. I guess I might have an aftermarket one and dont know it? I' will crawl back under and check it out soon. The reason I dont want to replace the rack myself is because it seems a bit intimidating for someone like me who has never done it. I really dont know enough about power steering systems, otherwise I would pick up a rack off here and give it a shot.... I hope its nothing more serious then the rack.. More input would be nice about possible reasons for the problem, and even better, solutions!
09-13-2008, 08:59 AM | #72 |
You are shittin me, the guy at the auto parts store assured me that I need that exact power steering fluid......... FUCK!
well that could be the problem.......... Is there ANY WAY to fix it? How do I get that other fluid out of there, if possible?
09-13-2008, 09:56 AM | #73 |
wow, both me and you are newbie? Idk I did some googleing and apparently PS fluid and ATM fluid are the same thing, except one resists heat more. So I should be fine, meaning my problem is something else....
09-13-2008, 01:30 PM | #74 |
Trader Rating: (73)
Feedback Score: 73 reviews
As long as you haven't been driving it much you should be able to drain the rack and put the right fluid in before it does any damage.
ATF is better for the seals in the PS rack, that's why it's recommended for Nissans and other cars that are specified to use it.
Best way to do business with me? Make your best offer FIRST. |
09-13-2008, 11:00 PM | #75 |
Rack
Ok guys, so im pretty sure im gonna buy a rack, question is, should I install it myself or hire a pro? You saw how newbie my post's were so you be the judge. I got a chilton guide, some random nissan guides I downloaded, and you guys here on zilvia. Yes or No?
09-14-2008, 12:03 AM | #76 |
nice job puttin shit back together. i had the same destruction wen i hit a curb. tension rod, and lca were fuked. what kinda shitty alignment shop did u go to? did they not test drive it and report back to u? i would go back there and complain O
lexus baby |
09-14-2008, 06:51 AM | #77 |
AFC #1
Only thing you can fuck up is the steering wheel alignment to the rack. The rack has a Dot/Slit for alignment. Make sure you get a Oil or paint marker and mark that point on the steering rack. Then align that with the new racks dot/slit.
The rack has a cradle on the drivers side so you can't screw up locating in in the crossmember. I recommend getting some upgraded rack bushings while you have it out. The stock ones are like foam rubber.
Comments should be taken as Opinions not as Statements of Fact |
09-16-2008, 08:49 PM | #78 |
The rack isn't too hard to switch out if you've got the time and are patient. But my experience doing it was with full access to my lift and an extra set of hands so it will most likely your experience will be a little different than mine but I think you will be fine with it judging by how well you did the rest of it. I'd say go for it and try it yourself!
09-19-2008, 06:04 PM | #79 |
Update
Well im gonna get the rack in a couple weeks, delay because of fundage... Something else I noticed was that sometimes when I make tight corners or go over a bump I hear strange "stress" sounds. Is this because of tightening the shit when it wasnt under full load or is something comming loose? LOL I dont want to die, ya know how it is....
something ELSE I noticed too, is when Im driving, if I put my foot in it and take it to redline then shift, when I hit the next gear the back end of the car will feel floaty for about a second, im wondering if its losing traction? tis a mostly stock s13................ idk whats up...
09-30-2008, 02:48 PM | #80 |
whats up
any info on the car? I know what you mean by floaty my s14 has fuked up alignment in the front and i get that its lack of traction at the front there is some play at the front i wouldn't drive fast in bends or rain i think your car may have some fuked up toe out configurations check your tires they may tend to wear out very fast and give you a good idea of how your alignment is messed up keep us posted on how you fix it
ﻱ |
01-18-2009, 07:49 PM | #82 |
Rack
OK, so its been a while but I finally got my hands on a rack... I got by with shitty steering for a while, it was by no means safe.. Anyways now im trying to figure out how to put it in. I have never worked with power steering so if someone could give me a quick breakdown of the steps I should follow I would be thankfull.
01-18-2009, 08:00 PM | #83 |
01-18-2009, 08:23 PM | #84 | |
AFC #1
OP, what problems are you having with installing the Rack? Just need a general walk through? Get some new rack mount bushings. Stock ones are spongy rubber.
01-19-2009, 12:03 PM | #86 |
rack
Well I can handle all that other stuff, i just dont know if there is anything I need to do as far as flushing old fluids, or anything I need to know about power steering plumbing, if not I guess I could install it on the weekend... but it IS my DD and I do have to go to school so I just wanna make sure I can get it in without too many problems.
thanks guys
01-22-2009, 10:07 AM | #87 |
Sr20
Guys, im sick of my oil burning KA... I wanna change it out for an SR20 (or RB20) in the next few months. As you can see from all my posts I dont know SHIT! I dont even know how to use a cherry picker.... But how else am I supposed to learn?
Does Zilvia think this is a good idea? I would be changing out my SOHC, so I'm not sure if that means anything different from the DOHC KA. If you think this is a good idea I would appreciate it if you guys could recommend especially noob friendly guides. I think if I actually do this I will video tape the whole thing so other new guys (like me) can do it too. p.s. Still hav'nt put that rack in, but I think I will do it when I change the motor, that way I dont have to have a ton of downtime for my DD.
01-22-2009, 10:49 AM | #88 |
I honestly have to say this is the BEST new forum member EVER.
Holy mother of god. I love this kid. He took lots of pics, wasn't afraid to ask questions. He dove right in! Now he wants to do a swap. I think you can personally do it. Just be sure to research on the swap. The best gain of knowledge in these areas is experience. Start wrenching and you'll grasp it. I am so impressed. Do NOT get an RB20. I do not want to start a flame thread on the RB20 but for the love of god do not get one if the debate is SR20 vs RB20. SR20 is lighter, capable of the same numbers stock and has less rotating mass. Swap: JDM Zenki S14 SR20DET swap into a DOHC S13: SR20DET Forum (rear-drive): Nissan Forums / Infiniti Forums - NICOclub (wiring for S14 SR) S13 SR20DET into a 1st Gen 240SX S13 SR20DET into 89-98 240SX Wiring: SR20DET Swap Engine Harness Wiring Diagram Guide SR SR20 If you ever need help, feel free to email me. [email protected] |
01-22-2009, 11:40 AM | #89 |
Thanks!
Awesome links man! thanks a lot! and like my first compliment! woo! haha!
if anyone else has more to add I would be thankful! what should I consider upgrading on the SR before I install it? I have heard flywheel and clutch are important to change. Anything I could do for some easy/cheap power gains? I know absolutely nothing about turbos lol
01-22-2009, 11:53 AM | #90 |
video
lol for fun me and friend made a flyby vid, i was kinda bored the other day. You can see a flame shoot out the back- im pretty sure its from burning oil. The car also has an ECU upgrade of some sort so that might be part of it too
after a while of not washing my car my back bumper gets charred, again I think from the burning oil. I have to add oil every couple weeks- NOT GOOD. link ===> YouTube - 240 burnout than flyby
Tags |
broken, owned! |
