95 240sx wheel backspace question
I have a 95 240sx and I am ordering weld rt-s wheels 15x10. I am doing a 2jz and aiming for 7-800hp+ that's the reason I'm going so wide I plan on running m/t street radials. Does anyone know the backspace I need to order?
Thanks in advance |
![]() Join Date: Sep 2006
yes.
google 'maximum backspace s14' or something along those lines
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
10"s arent even that wide, especially for the power youre looking for.
its simple math. if you have a 10" rim and it has 5.5 (6.5) inches of backspace, you will have 5.5 (4.5) inches of front space. go look in 'fitment' forums and what not to see what sizes people are running.
![]() Join Date: Jun 2003
I have a set of spinwerks in that size, I don't know the backspace off the top of my head, but I can check when I get home. The back was easy, the front is the problem, are you just doing a pair in the back?
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
what size tire/rim you went with back space?
I plan to run these with 6.25 backspacing these dont need special lugs http://www.latemodelrestoration.com/...tainless-94-04 |
Same exact setup I have the only thing is that I had to use ksport suspension because it was hitting my kyb struts(which were coming out anyways) but the clearance from the ksport to the inside of the tires is VERy minimal. It's like a 1/4 inch but I don't think it's going to hit.
#12 | |
