Old 08-30-2012, 01:54 AM   #1
3v1Ls14
3v1Ls14's Avatar
3v1Ls14 is an unknown quantity at this point
s14 RB20DET revving problems??
yes have searched on google and all sorts of Nissan forums
..and yes i know its a problematic RB
Here's how it is..
Starts ok and idles ok, has had slight miss and stopped firing one cylinder, new plugs and fixed the miss.
It will idle fine and rev ok, but wont rev past certain rpm almost like a fuel cut. try driving it and soon as its about to boost it chuffs black smoke and loses power, but doesnt die.
fuel pressure is good, 40psi at idle or just under. have tried known good maf, known good ecu. injectors all working well and have specified impedance. I have continuity tested every wire in the loom from ecu plug and checked for accidental earthing out in ALL wires.
tried unplugging tps, same result, o2 sensor, same result, afm, same result, idle valve, same result, temp sensor, same result.
i am getting ecu code 55 so no fault. new plugs, good afm, good ecu, new temp sensor, standard turbo, good fuel pressure.
no matter what i unplug the conditions of how it is running do not change.
even if i unplug afm and try rev doesnt die or anything. just revs up a bit then hits the cut EVERY SINGLE TIME. getting very frustrated and running out of ideas. dirty fuel? air leak? any ideas or suggestions would help. cheers guys
3v1Ls14 is offline   Reply With Quote
Old 08-30-2012, 02:14 AM   #2
budderigs
budderigs is an unknown quantity at this point
Sounds like wrong maf. Or wiring issue going to the maf. Which maf are you using. The rev cut is a typical maf related issue on rb's
budderigs is offline   Reply With Quote
Old 08-30-2012, 02:20 AM   #3
3v1Ls14
3v1Ls14's Avatar
iv tried 2 mafs. was running previously sat for a while and now having this prob.
maf has been rewired twice brand new wires and sheilded wire. plug changed with a mint one as well. soldered and heat shrinked etc
ran fine before just since i have put the turbo on its doing this. turbo had almost no play at all, a mint turbo basically.
mafs used r both j60 green sticker series 2 rb20 rounded plug type
Old 08-30-2012, 02:42 AM   #4
budderigs
Check for plumbing leaks between turbo and intake manifold. Maf to turbo. Bypass valve and crankcase vent.
Just about any intake leak will cause an issue.
On mine I had the same issue. Found that I wired the maf plug looking at it backwards. Switched the wires around and it fixed the issue. Then when I swapped to my Greddy turbo it did it again when I missed the bypass valve.
Old 09-09-2012, 02:58 AM   #5
3v1Ls14
3v1Ls14's Avatar
i have changed loom and new ecu as old ecu blew when afm shorted out. new loom and ecu now wont start, 42psi fuel pressure when it primes, has spark, almost fires but doesnt, makes dull popping from exhaust pipe but just wont bang properly.. any ideas?
Old 09-09-2012, 03:12 AM   #6
budderigs
what does it do with the maf unpluged now. if the maf is unplugged, the computer will ignor most of the other sensors and do its best to idle. so try unplugging it. and see if it starts?
what model number computeer did you install now? its not as commen on rb20 computer as it is for 25's but some of the computers are pinned differrent. s1 or s2 rb20s have different pinout's as wel/l as different sensor outputs and different intake manifolds. is your 20 a redtop or gray
Old 09-09-2012, 03:15 AM   #7
3v1Ls14
3v1Ls14's Avatar
maf unplugged doesnt start either. i put more gas in, checked plugs they were fouled up so i cleaned them all and tried again, same result, dull popping during cranking. ecu showing 55
i installed ecu 23710 04U11
i last had in an 04U12 i know the codes are both rb20det r32 a/t ecus so no reason why it would be different
silvertop motor as well.
i have checked injectors by turning cas and all 6 are operating and i am getting spark as well, good fuel pressure, ecu is turning on properly etc
pretty confused and stuck at moment
Old 09-09-2012, 03:52 AM   #8
budderigs
timing off? do you have a timing light to check it? if it is popping through the exhuast the timing would be late. try turning the cas counter clockwise to the max. and see what happens. if it hard cranks back the timing a little. if it starts make sure you get a timing light on it asap and set timing at idle to 20
Old 09-10-2012, 03:02 AM   #9
3v1Ls14
3v1Ls14's Avatar
all timing marks line up properly on cams and crank pulley. i have had it set in middle both sides and almost everywhere in between, same with the tps.
just pops a lil bit of black smoke when it does pop, not wet spluttery black smoke though more like sooty kind of smoke..
all 6 injectors clicking, plugs firing. injector plugs are on the correct injectors as with coil plugs.
does same thing with idle unplugged, afm unplugged, o2 unplugged
Old 09-10-2012, 03:08 AM   #10
budderigs
Plug everything back in. Turn the cas all the way to the left(counter clockwise) then try to start it. Feather the gas pedal a little and see if it starts. It now sounds like your ignition timing is off. The computer probably has a different curve programed in it.
Old 09-10-2012, 03:12 AM   #11
3v1Ls14
3v1Ls14's Avatar
factory unmolested ecu from a factory rb20det gtst skyline r32. i have tried feathering gas with cas at fully counter clock and also fully clock wise. ive tried WOT and no throttle and partial throttle and tapping throttle. the ECU was previously running a 30DET (poorly) but dont see how that would change ecu's inner workings.
the small puff of black smoke makes me think it is fuel related..?
Old 09-10-2012, 03:14 AM   #12
3v1Ls14
3v1Ls14's Avatar
also the pop got louder today, almost sounded like a back fire but not enough heat to ignite it for it to be a proper full on back fire just a loud pop and small black chuff
Old 09-10-2012, 03:16 AM   #13
budderigs
Also get a dvom and set your tps too .4-.5 volts. You have to narrow down the problems not make more.
Old 09-10-2012, 03:20 AM   #14
budderigs
Do you have a 3"to 2.5" coupler laying around?
Old 09-10-2012, 03:21 AM   #15
3v1Ls14
3v1Ls14's Avatar
i have silicone a one yeah
Old 09-10-2012, 03:30 AM   #16
budderigs
Cool might need that.
Can you get the compressor housing cover off your turbo? Check and make sure it didn't lock up? Also check it for play.
Old 09-10-2012, 03:31 AM   #17
budderigs
Also pull off your down pipe in case the exhaust is plugged.
Old 09-10-2012, 03:34 AM   #18
3v1Ls14
3v1Ls14's Avatar
i will try both next time i can work on it and see if any change
Old 09-10-2012, 03:38 AM   #19
budderigs
I am starting to think this is getting over thought try the simple stuff. Maybe recheck your plugs and do a compression check just to make sure.
Old 09-10-2012, 05:27 AM   #20
Nidd
Nidd's Avatar
Nidd is an unknown quantity at this point
Are you lining up the half moons on the cas and cam when you reinstall the cas? If they aren't lined up it'll run funky or not at all.
What RPM does it cut out at? If it's going into limp mode and stopping at 2500 it could be maf related.
Also check the ignitor to make sure it's still good. Had some miss problems with my rb's and switched to z32 and seems to work better now. Easy swap to do.
Nidd is offline   Reply With Quote
Old 09-11-2012, 02:52 AM   #21
3v1Ls14
3v1Ls14's Avatar
not running at all now. wont fire. i pulled ecu out and opened it up, was told it was a standard gtst r32 ecu when i bought it. i notice it has mec r109 on the top cover. on the side it says mec r127. inside its actually neither, its chipped. so probably chipped for something completely different. have a standard one now that i borrowed from a work mate. i will try that in the next couple days and see what happend.
my cas is keyed into the cam gear so it can only go in one way
Old 09-11-2012, 07:17 PM   #22
preston240sx
preston240sx is an unknown quantity at this point
problems
sounds like a maf problem ... seems the ecu is telling the injectors to flood it .... my rb20 hard starts alot and wont start ,,,ill unplugg the maf it will fire right up plug it right in andthe car will run fine ... i still get the 55 code lol
preston240sx is offline   Reply With Quote
Old 09-12-2012, 02:58 AM   #23
3v1Ls14
3v1Ls14's Avatar
doesnt fire with maf plugged in or unplugged and ive tried another maf as well
Old 09-14-2012, 10:21 PM   #24
3v1Ls14
3v1Ls14's Avatar
update: i got it started the other night, i pulled cas out, and the half moon key from the cam was STUCK IN THE CAS. i never knew it was broken when i got the motor i just assumed i must have slipped cas back in perfectly every time. so i lined it up at tdc and saw where it was broken on cam and lines the cas up opposite to that and put it in. fired first time.
i have now got it running and everything, but if i blip the throttle to maybe 1/4 it will rev out and hold the revs there on its own for a little bit, and has a horrible miss when i drive it, but only off boost. as soon as it hits boost it pulls hard and stops missing, drives normal ON boost but shit OFF boost. any ideas as to where to start looking? i have seen many people problems ON boost but not off where as im having opposite problem
any help would be good if any one has had similar problem
