Old 08-09-2011, 02:06 PM   #1
flatblack90
flatblack90 is an unknown quantity at this point
Autometer gauge cluster help
So I got an autometer cluster for my s13 boost air fuel tach and speedo problem is I cannot get my speedo to work at all its a mechanical one 4493 any help would be appreciated
flatblack90 is offline   Reply With Quote
Old 08-09-2011, 02:48 PM   #2
Nachtmensch
Nachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond repute
What vehicle is it installed in? The mechanical speedometer requires a cable going to it. The easiest solution would be to run a electric version of the speedometer and tap off one of the speed sensor wires. One wire will be the high and the other the low signal. Then just calibrate the speedometer by driving the 2 mile distance as outlined in the calibration procedure.
Getting a cable to work with an S-chassis will be much harder. If it will work, Speedometer Services out of Milwaukee will know the solution. Their number is (414)463-6660 (I do not work for them or are affiliated with them)
Nachtmensch is offline   Reply With Quote
