Old 06-30-2014, 10:39 PM   #1
terrance john
terrance john is an unknown quantity at this point
nx1600 digital cluster wire up into a rb20 questions.
hey guys i just put a rb20 into my 240 using wiring specialties wiring harness, but i am not sure what to do from here.i would like temp,rpm tach,and fuel to work and the obvious other sensors. if anyone can give me a guide or point me in the right direction on how to get it done ill greatly appreciate it.
terrance john is offline   Reply With Quote
Old 07-06-2014, 09:34 AM   #2
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I'm going to go out on a limb here and say that the Tach won't work because it's a 4 cylinder tach. The other stuff might, You would need something to convert the tach signal down for the tach to understand.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 07-10-2014, 02:31 AM   #3
terrance john
im going to use a dakota digital tac converter
Old 10-20-2014, 09:38 PM   #4
fsuarez
fsuarez's Avatar
fsuarez is an unknown quantity at this point
Send a message via AIM to fsuarez
any update on getting it working?
planning on doing the same
fsuarez is offline   Reply With Quote
Old 10-20-2014, 09:45 PM   #5
WheelWhore
WheelWhore's Avatar
WheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymore
I have looked into it as far as putting a S2k cluster in mine. Seems more hassle then worth the effort.
Everything should be the same with the exception of the tach and the mph. Youd have to find a way to convert the signal from the VSS and the Tach.
I would imagine just some fiddling with your Dakota. Everything else will be the same wiring wise.
WheelWhore is offline   Reply With Quote
Old 10-20-2014, 09:58 PM   #6
foreverdeath
foreverdeath's Avatar
foreverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the rough
the tach will work i put one in my roomates rb25det neo s13, but it will read 1.5times as high. he got ordered a dakota digital to correct it but havent seen it yet is ive been outa town.
foreverdeath is offline   Reply With Quote
