#991 |
![]() Join Date: Jun 2011
Update!!!
New Video logs on here along with written blog updates. Going to be trying a new format with video logs as well as written updates. Which do you guys prefere?! Check it out! https://www.youtube.com/watch?v=J-GqrGmfKt4 Thanks guys!!
IG:@AAPARKAH #ThisIsTheWolf |
#992 |
Update!!!! "Level Up with Parts Shop Max - Damage Control"
Episode 5 is up!!!! Like, share, comment below if you'd like!!! And or on youtube as well!! I'll be typing a some extra info on this tonight when I get back from my trip down south!!! https://youtu.be/p2kZ9HSs970 Thanks again guys!!! How's everyone liking the Video Logs?
#993 |
Update!!!
Here is Episode 6!!! Vlog! https://www.youtube.com/watch?v=fRJ6zrAq4AY I am going to try and edit Episode 7 Yellow fin tuna Fishing and almost sinking in International waters tomorrow...or possibly on the plane. *I'm headed to Japan guys!!!! Pretty pumped! I leave tomorrow At 1 AM from LAX. I'll be headed to the first ever FIA Drift Event! I'm really thankfull to be a part of history. *Formula Drift is Very Serious. *But with FIA...it means that the world recognizes drifting as an official Motorsport! *It's Massive! * Anyways... I'll try to Edit Episode 8 on the Plane as well *And hopefully Episode 9 Will be Formula Drift Texas!! and 10...FIA and Japan!! WOOO!!! The car is repaired. *She's doing well...and I did something big!!! Looking forward to sharing everything with you guys asap. *Thanks for tuning in and for those of you who believed in me.. Thank you ALWAYS for the Support!
#995 |
Continued!
Episode 6.5 "The First Ever FIA Sanctioned Drift Event" Taking part of a historical Event!!... This is Epic guys!!! Part 1 and Part 2! Part 2 is much better than part 1....so If you need...skip the first Video and go to the Second haha. Lemme know what you guys think!! Also if you guys want to help...do feel free to share any and all of these links on your facebook and or Instagram!!! It all helps!! Thank you Either Way!! Part 2 - Episode 6.5 https://www.youtube.com/watch?v=35Qa...xgsgyBGXeF4xXE
#996 |
Episode 7
It was always a dream of mine to take the Wolf to SEMA.* Little did I know it would happen so unexpectedly.* A few months back I got a call from Borg Warner asking me if the car would be Available for SEMA in Vegas.... I hit the wall at the last event..but I said Absolutely!! YES!. And it happend.* It was so epic guys!! Dream come true!!!* *Vid Below of an interview done by Race Car and Chill.* Featured on the new Partnership Youtube Channel "Corner Balanced" Put on by one of my Rx7 Buddies!.. Mr "Grandmighty" himself...whom've which I met on the Forums here!!! Check it!! https://www.youtube.com/watch?v=35Qa...xgsgyBGXeF4xXE
#997 |
Update:* SEMA PREP!!! ApLyfe Ep, 10
https://www.youtube.com/watch?v=jxM3oPpb-jE&t=101s Also... Shhhhhhhh.... I may have done a thing.... A big thing.* Spent the last couple years buying and selling higher dollar parts and finally reached my goal. Purchased a 5-Speed Sequential Gear box last month.* Sat down with the driver of my new Team in Formula Drift and we went over some Gearing for Wheel Speed and Rear end Ratios.* The whole goal was to solve a few very Huge Issues that were plaguing me...but then Also prepare for the future etc. The first thing is Strength.* This last season I lowered boost the entire year in order to lower the amount of gear boxes I was going through.* It helped..but then I had to give up power.* With the new gear box... I'll be able to reliably put the power down.* There were a few options but in my opinion they just werent up to the task.* Drifting really is probably the hardest thing you could subject a car to.* Shock load, Rev limit, Heaps of grip (Hence breaking 8 OEM Boxes, seven of those being 3rd gear and one being second gear). But you have to drive aggressively....otherwise you'll be left in the dust by everyone with tq...aka everyone else. My buddy with a semi pp street set up broke an oem 3rd gear down shifting from 4th on the freeway.* He is making good power (540 Whp)...but they are just fragile boxes.* They actually feel really good with nice shifters on them...but It was time to say goodbye and stop destroying Genuine Mazda parts haha.* With the box having close ratios...it'll put me at an advantage over a standard 4 speed because yes maybe i'd have the strength...but I'd have even less useable gear.* If I was going to drop a big chunk of coin...I was going to think it out completely.* Other Boxes..like Cd009...and or T56 etc...* Stronger....but not dedicated Gear boxes.. Heavy, Bulky....Not ideal gearing, and H-Pattern... AAAAnd most of all.. I'd stil need to do all the same hard work.* Plus, adapter plate... A bell housing, possibly source a turbo2 bell... then toss all my alternators and source new ones... trans tunnel mount, rear end reinforcement... Before you know it your 30 hours deep trying to piece together something that will "Work."* And a few people suggested going with upgraded gear sets...in the FD OEM Box.* I'm just not convinced.* If the Drag guys aren't using them for some reason... then there must be a reason for it.* For a car that may see street use...it seems kind of expensive and time consuming.* Is it proven?* Who knows....but the fact that it isn't...could be the answer. So I opted out.* And Went full in on the HGT 5-Speed.* I also went ahead and chose the 26 Spline... Its just a bit more Burly and far more available in a bind for Clutch Discs if the event occurs.* The Box came with a Cast Bell Housing, Hydraulic T/O for the conversion to Push Type, A slip Yoke 1350 Series adapter, Gear Position Display, and my choice of shifter.* There is a New Design that is all Black Billet Alum.... I didn't like it.* I requested the old style Silver with Carbon Inserts and Black Shift knob.* It just looks more quality IMO. I've made my own Transmission Brace and The PPF Will finally be thrown in the Garbage. It's the Bane of my existence...and added Hours onto my Gear Box/Clutch/Diff Swaps.* Total Pain and I can't wait to Get it out of the car.* The Shifter Is center tunnel designed but Remote....Therefore I can offset it up to 15Degrees from the Gear box and it still work fine.** I'm really looking forward to this guys.* Stay Tuned! More updates soon! Also..drove the car one last time this past weekend.... Broke 2 Axles* coming up over a long Elevated Right hand turn at Sonoma Raceway.* Weirdest Feeling ever.* Look at that Break Thanks for the Support guys!! I'm missing this Forum Hard out!*
#1000 |
Thanks Guys!!!
Update!!: Breaking Axles at Winter Jam on the Stock Gear Box Vid Below: Update!:** https://www.youtube.com/watch?v=Hjyx5Sb8CtU ALso...if any of you guys are on IG.. Feel Free to help me out and give me a Follow. I'm really trying to step up my Social Media Game. It helps a lot with Sponsorship! Zilvians Unit!!!! Give me a Follow!!! Tell me how much you hate me... Love me...or wish I choked on my own Breath lmao. IG: AAPARKAH.300 Thanks Either Way Guys!!! Gear Box Video Coming out ASAP!
#1001 |
Update:!!!! I need Zilvians Help!!! PLease Follow the Link and Gimme a Sub!! Trying to Make the Cut on Youtube to Help Monetize my Vids!!!!
Is is Begging for Subscribers? Or...... So here's my Issue. It's almost like one of those "Richer get Richer, Poorer stay Poor" Types of deals. And in our world "Drifting Automotive," If you didn't come from money... this rule really hits hard. Why? Because 99% of the guys trying to get in...aren't going to have time to pump out Youtube Videos, edit, and film the content they need in order to compete with the "Full Time Content guys." There's nothing wrong with those guys...and I'm def Not talking crap... But this Youtube Rule Segregates the dudes who're heavily grinding and in the shit running their own programs trying to make it and get a Toe in the door,...VS the guys who may be using "Drifting" as content yet may not be heavily invested into it. I don't agree with it...but it is... so Here's what I'm doing.... I'm trying to make it. So If you'd like.. Go give me a follow and Subscribe and tell me how you like my Content. So DISCUSSS!!!!!!!! What do you guys think?! Pasted Message Below from my Home Page: To the Maximum driftcast Bois.... Excuse me if I spam the hell outta my Youtube Vidz...haha. So I've been saving up all my Episodes to do a full 15+ series release. But that one totally bit me in the ass with this recent Youtube SUbscriber/hour Minimum lockout. Lets see if I can make the Cool kid Cut!!! LIke, Share, .....tell me how terrible I'm doing... I don't care as long as you subscribe and gimme your time!! ;-) https://www.youtube.com/channel/UCTh...c3HFhKxQHuZPqQ
#1002 | |
![]() Join Date: Feb 2007
Determined to be famous, destined to be infamous.
#1003 |
New APlyfe video just went live! Test fitting the new HGT Sequential Gear Box in my Rx7! #ThisistheWolf #HGT #Rx7 #Sequential
https://youtu.be/QF1blA31kC8
#1005 |
#1006 |
![]() Join Date: Dec 2009
I know reviving a old thread is taboo but Im watching domut medias video of this car and amazing how far its come,How many of you noticed he was on donut media?
https://www.youtube.com/watch?v=j_Mv2i7pTKw |
#1007 | |
![]() Join Date: Sep 2012
Its really going to blow your fucking mind when you watch the HiLow build series....
@jz_2tone |
Tags |
adaptronic |
