Old 05-12-2011, 05:42 PM   #1
BlkS14Drifter
BlkS14Drifter's Avatar
BlkS14Drifter is an unknown quantity at this point
2 post battery disconnect question
Is it posable to have 2 (2 post) battery disconnect switches, one on the inside of the car and one on the outside of the car? And have them both work?
Newhall Muffler & Fabrication (661)287-9018
BlkS14Drifter is offline   Reply With Quote
Old 05-12-2011, 06:14 PM   #2
240sx .25mile
240sx .25mile is an unknown quantity at this point
like a 3 way switch?
240sx .25mile is offline   Reply With Quote
Old 05-12-2011, 06:20 PM   #3
BlkS14Drifter
2 battery disconnect switches in series! One on the outside (mounted) of the car that goes to the battery and one inside the car (or you) that goes to the battery... But there both two post battery kills..
Old 05-12-2011, 06:23 PM   #4
240sx .25mile
on the same circut? that would be a 3 way switch. you would have one in your car and one out of your car. if you turn the switch outside of your car, you can still turn it on inside your car without getting out of your car. vice versa.
Old 05-12-2011, 07:25 PM   #5
BlkS14Drifter
Yes but my problem is that you can't shut the off the car with switch because the alternator keeps the car running... So I got the painless Altnator shut down relay! So I hooked it up to the kill inside the car... And it works but I'm trying to get the outside obe to work the same way...
