Old 11-28-2017, 12:59 AM   #1
nisans13turbo
nisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nice
S13 coupe rear bumper gap help
So i noticed that there is a 2 finger gap between my rear bumper and the center garnish below the taillights. Any tips of how to fix this gap? I don't see anything that is holding the two piece together.
Thanx
nisans13turbo is offline   Reply With Quote
Old 11-28-2017, 01:07 AM   #2
nisans13turbo
Old 11-28-2017, 05:53 AM   #3
Sailor
Sailor is a well-known jackass
Double check all your fastener connections. If they all look to be in the right place, you can take some fiberglass and build up that gap to be completely flush for a seamless bumper- though this would require a repaint at some point
Sailor is offline   Reply With Quote
Old 11-28-2017, 09:24 AM   #4
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
There are several 10mm nuts holding the rear bumper to the quarters that you can reach down/see on the inside of the trunk. 4 on each side I believe. double check they're all there and tight. kind of hard to see but if you reach down there you can feel them. maybe that could help.
EnnEssEnnKAT is offline   Reply With Quote
Old 11-28-2017, 10:26 AM   #5
Sailor
Is there a lip that the top of the bumper slips into/rests on? The bumper would look like it is poking out by the right tail if it wasn't sitting on that lip, if the lip was bent you could end up with that gap
Old 11-28-2017, 06:52 PM   #6
nisans13turbo
All the nuts are tight. Are there suppose to be clips to hold the center of the bumper?
Old 11-28-2017, 06:54 PM   #7
nisans13turbo
No. This just doesn't make sense lol because over time the center of the bumper will sag
Old 11-28-2017, 07:31 PM   #8
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Correct me if I'm wrong but doesn't Street Faction claim that their rear bash bar fixes this?
[email protected]
hanzbrady is offline   Reply With Quote
Old 11-28-2017, 09:59 PM   #9
pacotaco345
pacotaco345's Avatar
I have a street faction bar and i use pipe insulation wrapped around the bar to hold it up which seems to work well. HOWEVER, if you have the stock rear crash support beam there's a piece that runs the length of it on the top that's specifically meant to keep the bumper from sagging.
OP, do you have the stock crash beam? If not, and all that's holding your bumper on are those 4 bolts on either side then of course it's gonna sag.. It's a 25 year old piece of polyurethane with nothing holding up the middle lol
Old 11-28-2017, 11:30 PM   #10
nisans13turbo
Hi, yes i do have the stock crash bar, can you link a photo of the support beam piece your talking about.
Thanks
