Engine Tech Technical discussion related to all relevant engines such as KA, SR, RB, CA, 2JZ , L24/26/28, VG, VQ, and LSx series. |
![]() Join Date: May 2012
![]() ![]() Feedback Score: 3 reviews
RB25DE+turbo conversion discussion
Hey zilvia
So, my skyline has a rb25de that im starting the conversion to turbo. For me i like the idea that its about 1/3 of the cost of swaping for an rb25. the motor already has plugs for oil drain and water lines for turbo. i also like the idea of higher compression and a quick spooling turbo. also, i dont plan on going high hp. i daily drive the car and am just looking for more power for local drift events. Help me out, tell me what i may be overlooking. also anyone that knows these engines well, any advice would be appreciated. my drift car had an LS for the past 5 years so rbs are new territory. Parts i have so far... -DET stock injectors -DET coilpacks if needed -AEM fuel pump -oil and water lines -downpipe -intake piping Needed... -ECU series 1 -intercooler and piping -stock turbo -ex manifold -stronger clutch hoping i can just bolt this stuff on and the stock ecu will run things fairly well. simpler tuner recomendations? thanks |
![]() Join Date: May 2019
If ur gonna keep stock ecu youll need a a tuner to work with that, nistu ne,romtune, something that will work, timing will be important since ull be running higher compression. What fuel will u be running...
you get into tuning, you're getting into big money close to, if not the same than swapping to a det.
Then again, rb25det stock ecu's are really shitty, so even with a complete det, you may end up upgrading the ecu at a later point, so maybe just do it now?...
Tuners are big bullies ![]() |
yeah, thats a bit more than i wanted to spend, but it would be really nice to have a new ecu and good tune that i know will work great for me no matter what i do with the car down the road.
I tried that on my rb25. For some reason we could never get the mail in tune right. And I don't mean running perfect, I just mean running stable. martin tried a few different settings and still nothing. I ended up going nistune, and I also had some trouble with that. I could never figured out what was wrong with my setup. Most essentials on my car were new except for the maf which tested good. New WS harness.
Finally Martin did a session in my city and I grabbed a spot. He tuned my nistune and managed to get a decent number on a conservative tune, for a fraction of the cost I had been charged previously for a tune that didn't last. That ecu and tune lasted until the day I sold the car. Pretty sure it's still running out there. Martin is a legit guy. If you can make one of his mail-in tunes work with your setup I would go with that. His CS is unquestionable.
update.
turbo install is all done. had some issues with idle for a bit. some air leaks needed to be sealed up and vacuum lines ran better. ended up using gtr top feed 550cc injectors. direct fit. running on stock wastegate spring 8-10 lbs with 93 oct. so far all is good. just drove it at a local event. power felt great. |
