Old 03-25-2008, 10:29 AM   #451
driftstyre
driftstyre's Avatar
driftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond repute
Send a message via AIM to driftstyre
They are ITBs Working on a plenum revision now.
Just a few other pics of the front, new blades for the sway bars and the new Precision intercooler core.
driftstyre is offline   Reply With Quote
Old 03-25-2008, 11:23 AM   #452
wwiaftm
wwiaftm is an unknown quantity at this point
Bill that front end is amazing!!!
wwiaftm is offline   Reply With Quote
Old 03-26-2008, 12:57 AM   #453
jobestudios
jobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the rough
Hey bill, what is the specs on the tubing used to construct the front support structure. I want to make a similar style for my v mount with dimple died gussets
-Jackson.Vaughn.Photography-
jobestudios is offline   Reply With Quote
Old 03-26-2008, 06:18 AM   #454
driftstyre
driftstyre's Avatar
The small tubing is .5" OD, .049 wall 4130 chromoly. Id suggest TIG as it is thin but it can be MIG'd. For the lower splitter cage that bolts on to that structure, I have .4" titanium
Old 03-27-2008, 08:35 PM   #455
s13silvia123
s13silvia123's Avatar
my first time TIG welding
i was at work and was helping maintance do some work on a new machine since i had nothing to do all day. so here it is
my first attempt a little sloppy but my beads are ok to start with
my second attempt much better and not as sloppy as the first time.
sorry if i didnt clean it up but youre able to see the welds
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
Old 03-27-2008, 09:47 PM   #456
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Nice start.
Looks like the metal was not cleaned properly before welding.
Usually a proper tig weld will not need to be cleaned up. If it appears dirty, then that is usually because of a dirty welding surface.
Good for a start though. I would rec, that you just try to lay some beads on some flat metal. once you have that down joining pieces will be easy :-)
blu808 is offline   Reply With Quote
Old 03-27-2008, 09:55 PM   #457
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
I think this should be the first thing that anyone who wants to weld should learn, how to properly clean what you're welding. It will make learning a lot easier and your welds will come out better.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
Old 03-27-2008, 10:31 PM   #458
blu808
blu808's Avatar
Good point. I should have mentioned that. I spend more time cleaning each piece of metal than welding it.
Old 03-28-2008, 01:01 AM   #459
s13silvia123
Nice start.
the stainless steel that i was using was just scrap metal. i was bored and had nothing to do. yes it was dirty. didnt feel like cleaning it. but i'm thinking i'm gonna make something at work if i have nothing to do again.
yes you guys are right. practice makes everything better. next time i'll clean the metal surface so that its cleaner. but this was just practice for me. i do this every once in awhile when i'm bored. i'm trying to make myself better at welding.
i'm probably will be investing on my own TIG welder very soon. but i want a welder that uses gas. it seems like its much more easier for me to weld when i'm using gas. i have a hard time welding without gas. i usually end up with a really sloppy job.
i'm having a buddy at work teach me so i can become better.
Old 03-28-2008, 08:46 AM   #460
blu808
blu808's Avatar
Can you elaborate? All tig welders use gas.
Are you referring to mig? You can mig without gas if you use fluxcore wire.
Old 03-29-2008, 09:13 PM   #461
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
heres one of my first welds with my new miller
hopefully i have some neat parts to post up soon
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 03-30-2008, 12:34 AM   #462
projectdrifter
projectdrifter's Avatar
projectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of light
Send a message via AIM to projectdrifter Send a message via Yahoo to projectdrifter
i figure one of you fabbers can help me out. my question is the hump in the s14 i want to remove it so i can drop my seat lower. what gauge metal should i use. s14 hump on driver side. ii have seen a thread posted before of someone who did it but i cant 4 the life of me track it down. feel free to pm me a to not clutter this great thread up.
Mouth of the South
There are a few mailboxes that have been looking at me the wrong way, lately. Nothing goes unchecked.
projectdrifter is offline   Reply With Quote
Old 03-30-2008, 12:57 PM   #463
blu808
blu808's Avatar
18 gauge sheet will work fine.
Old 03-30-2008, 01:02 PM   #464
s13silvia123
yes mig my bad i should of said that in the first place.
Old 03-30-2008, 09:42 PM   #465
Brian W.
Brian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfection
Send a message via AIM to Brian W.
Originally Posted by DisEpyon View Post
the material is 1/8 aluminum plating, welded with 3/32 5356 aluminum rod, the machine was set around 145 amps (i set all my aluminum working high like that so i can control a wide range of heat) didnt use pulse or post flow and i dont remember where i had my ac balance at, somewhere between cleaning and penetration, most likely a little more on the cleaning side.
i fitted the plates with a corner joint, like in example c in the picture, then grinded the edges a tad bit to help give it a bevel
I have a question for those of you that weld on stainless steel alot,
how are you guys setting up your back purge system? details or pics would be nice. my brother bought some sch 10 manifold tubing material for me to practice on and im having a little trouble as to how to hook one up. Ive heard people using a seperate cylinder, or hooking up a y splitter some where on there machine or cylinder and running a hose off one end.
i use a seperate bottle with a regulator on it.. i have one small hose coming off of it that i then plug into whatever i am welding.
to keep the gas in the weld piece i either:
use tinfoil
or i bought some large "bouncy" balls from toys r us... i then belt sanded them into more of a conical shape and plugged a small brake hardline through it and hook the hose up to that so you can stick it in each runner of the header, and either tape or tinfoil up the other orifices.
^^^^ that worked REALLY well.
i also have a hole drilled in my welding table and plugged a barb fitting in to it that i can then run argon hose from the backpurge bottle to. then i can sit the tube or what have you that i am welding over top of that barb fitting on my welding table and then just cap off the other end.
also make sure to vent it out the otherside... depends on how much pressure you are running though.
www.ma-motorsports.com
-Fab work, builds, swaps, dyno tuning
Brian W. is offline   Reply With Quote
Old 03-30-2008, 10:35 PM   #466
DisEpyon
DisEpyon's Avatar
DisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to behold
Send a message via AIM to DisEpyon
use tinfoil
Thanks for the reply and info., also how much argon do you usually have the purge set to flowing?
DisEpyon is offline   Reply With Quote
Old 03-30-2008, 10:47 PM   #467
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
NOW THAT IS A GOOD BEAD!!
nice weld!
+1
HS13KLS is offline   Reply With Quote
Old 03-31-2008, 01:50 AM   #468
Brian W.
it depends on the volume of the work piece or how well its sealed...
just practice with some scrap material and see what works.. .start at like 7cfm.
Old 03-31-2008, 12:24 PM   #469
EJ253
EJ253's Avatar
i boxed in my subframes corners, i used 10g sheet metal
im going to box in a few other areas, ill post more pics then
Secret Society
Old 03-31-2008, 12:51 PM   #470
Wiisass
Wiisass's Avatar
10 gauge? I think that's a little thicker than you need. I don't think the subframe material itself is even half of that.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Old 03-31-2008, 01:51 PM   #471
GSXRJJordan
GSXRJJordan's Avatar
^^^ That's the first thing I thought too! Subframe looks like 16ga stamped pieces to me, but hey, maybe he just had some 10ga sitting around... can't hurt I suppose. Just a little more stress in the center of those pieces, rather than at the joints.
Old 03-31-2008, 01:59 PM   #472
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
EJ: Where in NC are you hanging out now?
Luke: Clear out your inbox
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 03-31-2008, 02:03 PM   #473
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
I always wonder why I don't see more people help out their sub-frame like that. I'm going to try to add Dimpled braces if possible when i get ahold of an extra sub-frame. Keeping everything out of the way and clean looking, while also giving the most support I can, is going to be the hard part.
burnsauto is offline   Reply With Quote
Old 03-31-2008, 03:24 PM   #474
EJ253
EJ253's Avatar
When I'm there I'm usually in charlotte, but I'm in Utah for the time being.
The the gauge of the subframe I should check it again, but I could've sworn it was thicker than 16g, I thought it was closer to 1/8th or so
Secret Society
Old 03-31-2008, 07:46 PM   #475
initial D
initial D's Avatar
initial D is an unknown quantity at this point
everyone does some sweet work from the pictures ive seen, ive wanted to get into welding for a while just unsure about what kind of welder to get.
And i have a rust hole in the floor of my car, what kind of welder would be used for that? would it matter what kind i used?
initial D is offline   Reply With Quote
Old 03-31-2008, 07:59 PM   #476
blu808
blu808's Avatar
thanks. Inbox cleared.
Luke
Old 04-01-2008, 03:34 PM   #477
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
Exclamation Centerline Intake w/q45 TB
Hey guys i just wanted to show you how the centerline intake plenum was coming along heres some piks of it coming together. Rich over at Excessive is a great guy and the only other plenum i have seen that is centerline &quot;throttle inlet between 2 and 3&quot; was that saurus time attack. Also we are doing a bolt on plenum for right now so we can switch it over to a normal front throttle body and check the diff. on the dyno.
TougeLabs is offline   Reply With Quote
Old 04-05-2008, 02:20 PM   #478
TougeLabs
TougeLabs's Avatar
Old 04-08-2008, 08:31 AM   #479
driftstyre
driftstyre's Avatar
I finished the endtanks for the intercooler and they might need a little tweaking but they are ok. I'd love to get some better metal fabricating tools...someday. I also got my dual wall 2.5" stainless bellows (from coast fab)for the wastegate return and the twin scroll housing for the GT30. Now I can fit the exhaust and then send the housing/manifold to swain for coating.
Also, this is a rotary powered Lotus 7 replica. The factory turbos imploded so I fabbed up a manifold and exhaust for the new 3071R. 2000lbs and this turbo should be fun
Old 04-08-2008, 09:15 AM   #480
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
as always bill excellent work!! that lotus must be a blast to drive
seems that the 3071 is becoming a quick favorite.
lazierhobo is offline   Reply With Quote
