Old 07-17-2010, 05:36 PM   #1
jroy1234
jroy1234's Avatar
jroy1234 is an unknown quantity at this point
Exclamation KA24DE IMPORTANT build question question
ok so i was putting in my NEW (new pistons rings, machined head etc.) KA24DE bc the shell i had had a flodded engine (gasoline). long story short: i used the same manifold fuel rail injectors etc of the old engine and when i went to crank nothing. again long story short: cylinder 2 injector was letting ALL the fuel go through it therefore flodding the new enige. When i drained it first came the oil then the gas(exaclty the same as when i drained the 1st KA)
MY QUESTION is: is the new engine (never started) ruined?
wat i did was fill it again with oil cranked it (w/o distributor injector and sparks connected) then drained it and i will let it sit on the lift over the weekend.
jroy1234 is offline   Reply With Quote
Old 07-17-2010, 09:52 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
i would be worried about washing out the rings, but then again i've only had this happen once
Slip Gypsies Blog
not sure if you realize this
Old 07-17-2010, 10:14 PM   #3
jroy1234
jroy1234's Avatar
how did that happen, the one you saw
Old 07-17-2010, 10:43 PM   #4
punxva
punxva's Avatar
Trader Rating: (31)
i had an injector stick open and drove it for about a mile on 3 cylinders
Slip Gypsies Blog
help 240sx, ka24de
