#3421 | |
I'm probably losing out on huge torque gains and better gas mileage since I'm a retard and mounted the nozzle after the ait sensor. Oh well she still drifts like a mofo and track proven times. 13.7 wot all the way down the track w/o meth, 13.8 @90 mph and completely letting off at the top of 3rd gear and coasted across the line(didn't feel like wearing a helmet). I'm at 6,000ft above sea level hence the slow times. |
#3424 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
guys, bit of odd trouble with my setup, looking for some input.
SR, 2871, 740cc, N62, RS-Enthalpy tune, yadda yadda car cranks up and idles fine. revs up and down fine. idle settles out to 13:1 or so AFRs. base timing is set to ~20ish, as best i can get it with the TPS unplugged and such. fuel pressure is at 3 bar where it should be. boost leak test showed no leaks. BOV flange is blocked off (so no release to atmosphere). no ignition break up issues. no ECU codes thrown. all seems fine and dandy. but (1) it feels a bit sluggish during hard driving, as if the ECU is pulling too much timing as it climbs in RPMs. (2) response is hesitant during quick shifts. and (3) when i drive it (i.e. when it sees load) and i clutch in, the idle drops to 500ish and tries to die (usually doing so). if i clutch in and feather the throttle, i can keep it alive and after 10 secs or so i can ease off the throttle and it'll idle fine again, blips revs and all. it doesn't seem to be fuel or spark... base timing is a tad advanced (~20 instead of ~15) but otherwise seems fine, at least at idle. no codes thrown. i'm baffled. any ideas would be greatly appreciated. EDIT: got the timing nailed down in the 15-17 range. the car still feels a little sluggish and the AFR only drops to ~13 when i get into boost. i'm out of ideas on why i'm running lean in boost. no post MAF leaks, fuel pressure is set correctly, no ECU codes.
![]() Last edited by jaysgottaredtop; 08-20-2013 at 05:12 PM.. Reason: update |
#3425 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
And yes, we mod stock manifolds to utilize external wastegates pretty often. Shoot me a PM if you are interested: ![]() ![]() ![]()
#3426 |
Bought Tomei poncams 256 11.5about 2 years ago at the time I felt like it would be ok for my stock Sr with t28 but I've just recently bought a bunch of stuff
720cc injectors z32 maf apexi hg Tomei Ras, springs splitfire coilpacks Greddy plenum intake manifold Megan exhaust manifold (free) Lightweight pulleys Bm fpr circuit sport v3 ss solid bushing Koyo rad 2 12 fans Greddy fmic Enthalpy tune Gt2871r .64 HKS hi power exhaust Greddy ebc Blitz fatt act Hdss clutch Tomei elbow aem wideband New cas and more my ultimate goal is around 380+/- and I'm thinking these cams might be too small for the goal I have but I don't want to shift the power band to far towards the top end because I want to drift it do you guys feel like these would be enough to match the rest of the set up or should I go bigger? |
#3427 | |
![]() Join Date: Nov 2010
I am pretty sure stock cams are good up to 400 hp, so with the poncams at 256, although not as large as you could go should support your power goals.
#3428 | ||
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Friend had the same issue with his stock setup and ECU. After exhausting everything out I told him replace the ECU. Runs perfectly fine now. He was also having issues being 13-14:1 AFRs under boost and feels like the power just drops off a cliff once it hits 5k.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#3429 | ||
![]() Join Date: Jul 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
I agree with ultimateirng, the 256 should be good for 380-400whp with all of your supporting mods. I didnt see the larger throttle body on your list of upgrades. I would look into the era1 72mm TB. they are local'ish and its a quality piece.
#3430 |
I didn't know the stock cams could handle that much haha from what I learned from this thread trying to match upgrades makes sense and makes power and efficiency if I did Di New ones I'd only go to a 264. I don't have an upgraded throttle body, I was considering a q45, but I thought I had read that a throttle body or throttle body spacer moved the powerband towards top end. but it didn't make sense to me. thank you guys for the info I will definitely look into era-1, I sent them an email today about the tb also I like the handbrake they have!
#3431 | |
#3432 | |
![]() Join Date: Mar 2013
my setup is 2871r, s15 injectors probably will upgrade to nismo 740, z32afr , built engine. only boosting 0.6-0.7 due to actuator issues |
#3433 | |
#3434 |
doesnt the snow performance kit have any failsafes? i thought about failsafes on mine , since aquamist has them, will work like this:
i will have the map over 1 bar tuned for water meth, and below 0.8 without. i will set the actuator's mechanical pressure at 0.8, and connect a relay from the failsafe to the boost controller's solenoid. if the failsafe turns on, it will cut power to the boost control solenoid, thus turning the boost to low, where engine is tuned safely. |
#3435 |
Side note: s13 has now hit 13.3 with a 2.1 60' and .2xxet. Still alot of room for improvement.
If it seems slow its because Bandimeres elevation is 6,000 something feet above sea level. The track is literally on the side of a mountain. It's pretty bad ass. Gonna fix an exhaust leak and some boost leaks then hit the track again for some more passes. |
#3436 | |
No fail safes on my kit as all it is a pressure switch, relay and an arming switch. Haven't wired in the solenoid yet, was just going to get a check valve. ill be checking the system today to make sure it's not clogged. As long as you run an inline filter you shouldn't run into any problems. Get a spare nozzle of whatever size you need so you can easily swap them out when one needs cleaned. My kit can be pieced together for less than $200 |
#3438 |
#3442 |
yeah but the water meth flow is constant while the aquamist taps into the injectors' pulse thus keeping the mixture relevant to the fuel injection... plus its got a nice gauge
![]() that mountainside track you say...is it downhill or uphill? :P |
#3443 | |
ahh yes, my bad i will try to stay on topic.
mountain side track is called Bandimere Speedway in Morrison, CO. its horizontal on the mountain, looks like it goes slightly downhill but it doesn't. |
#3445 | |
IACV is an issue if you idle is dropping below 500 and trying to die. Make sure it is powered and connected. Also they seem to be quite prone to sticking. So if any residue gets inside.. you need to take it off and clean the bejezus out of it.
As for the issue with running lean, i read the other reply, and i have no experience with burning out ECU. But if you have consult port hooked up, maybe you could run a log and see if the timing is actually being retarded. Quote:
#3447 |
#3448 | |
i think my main issue is my fuel pump wiring. i never rewired until now, and apparently a lot of people have issues getting enough fuel with stock wiring. i followed this (but with less ghettoness): http://www.ka-t.org/forums/viewtopic.php?f=12&t=59949 i'll try to take it out in the next day or two and see if that helps the lean in boost issue.
#3449 | |
![]() Join Date: Aug 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
#3450 |
![]() Join Date: Jun 2010
My datalogs show my 52 Trim .64 A/R, hitting my full 15 PSI at 4200 RPM. I have read in here of people hitting full boost sooner, ie. under 4k. What can be done to improve this? Is a matter of more timing advance in that range? AFR closer to stoich? Still using internal wastegate.
