Old 08-16-2011, 08:14 PM   #1
JDMxJosh
JDMxJosh's Avatar
JDMxJosh is an unknown quantity at this point
SR SR20DET Compressor Surge HELP!
When i unplug my waste gate, my BOV runs fine, blows off every time, even in low RPMs, no compressor surge, and it sounds exactly like an HKS BOV.
When i plug my waste gate, my BOV doesn't always work, its nothing but compressor surge, and i'd have to run it a few times to get the BOV to work, and it'd only work in high RPMs, and when it does BOV, the HKS doesn't sound right. But when its unplugged, sounds exactly like an HKS BOV.
thanks for your time.
JDMxJosh is offline   Reply With Quote
Old 08-17-2011, 06:24 PM   #2
JDMxJosh
JDMxJosh's Avatar
bump msg length
Old 08-17-2011, 06:39 PM   #3
Sileighty_85
Sileighty_85's Avatar
Most ppl give the BOV it own Vac Source
EDIT: In a sense the W/G kinda holds air pressure so when you let off its not pulling a strong enough Vac to open the BOV
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-17-2011, 06:41 PM   #4
Def
Weak vac source. Sounds like they're both on the same circuit. Make sure you have a dedicated line for both the WG and the BOV.
Plus HKS BOVs just like to make a ton of compressor surge anyway, especially at light load. Go with a bypass valve.
DEFSPORT
Old 07-22-2012, 07:56 PM   #5
Kzoodan
Kzoodan is an unknown quantity at this point
I am sorry to bring up old thread, but did this every get solved? JDMxJosh did you every figure out what was wrong or atleast how did you fix this? This seems to be very close to the problem i am having with my HKS BOV
thanks
Dan
Kzoodan is offline   Reply With Quote
