12-26-2011, 09:09 PM | #1 |
Vibrations? Help please
I own a 91 s13, and when i drive it..it sounds like the motor is way higher rpm than the rpm gauge reads and its vibrating pretty harsh. I looked under the car and im assuming the vibrations have made 3 of my drive shaft bolts fall out, so i replaced those..but can anyone please help with this situation? Thanks.
12-26-2011, 09:56 PM | #4 |
You need to be more descriptive.
Does it always vibrate? At certain RPMs? At certain speeds? When you do anything in particular? Stuff like that. There's a lot of spinning shit in your car that can vibrate. |
12-26-2011, 10:51 PM | #6 |
If you're RPMs are ramping but you aren't going anywhere, it sounds like your clutch is slipping.
The vibrating sounds like clutch chatter. Watch this and let us know if this is what you're experiencing: |
12-27-2011, 01:52 AM | #10 |
Does it only do it under engine load or in nuetral also? If it doesnt do it in neutral or at warm idle im pretty sure you need new mouts. If its shaking as bad as you say it may not be safe to drive.
