Old 06-28-2017, 05:37 PM   #1
na12uto
na12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-knownna12uto is making his/her stupidity well-known
SR ECU 23710 OA547 Help
Hello fellow Zilvians,
I am currently almost finishing up my swap, bought a s14 to s13 chassis from WS. Which says it works on WC/WR/WH Ecu's from Zenki S14's. Well when it came time to hook up the ECU I realized it doesnt fit. searching around, I cant find what ECU I currently have.
WC 23710 0A547
I know I need a WC 23710 69F00 Or WC 23710 69F01
So if anyone has information on what ECU I have at hand that would be appreciated. In the mean time I will keep on hunting and update when found
Found out the ECU I have is from the latest Model Kouki 97-98 S14 which will not work with the Wiring Specialties harness as it is for Zenki WC ECU's. For those doing the swap refer to the ECU model's I listed above.
A day late, a buck short, nothing zip ties cant fix
Last edited by na12uto; 06-28-2017 at 07:51 PM.. Reason: Update W/ Information I found
na12uto is offline   Reply With Quote
Old 06-28-2017, 07:52 PM   #2
na12uto
Mods, can close or delete thread as they see fit.
