Old 01-07-2012, 01:57 PM   #1
coupe92
coupe92 is an unknown quantity at this point
Center vent gauge help
I need some help on how to pop the middle vents out. I have the middle part with the fins that directs the air out, and the outer frame, but now the inside has the plastic housing that holds the two oval fins that direct air. Advice on getting this out? Also, the people that went this route, where did you drill for the boost line to go through, any tips on this?
coupe92 is offline   Reply With Quote
