12-29-2005, 02:57 PM | #121 | |
IT'S NOT SAFE TO MOUNT YOUR HARNESS (aside from that handy Schroth design previously mentioned) TO YOUR REAR SEATBELT BOLTS, OR TO ANY MOUNTING POINT LOWER THAN 20* FROM HORIZONTAL. BUY A HARNESS BAR. PERIOD. Your FIA-approved seat and 5-point anti-submarining harness aren't going to make you any safer when you ignore the basic principles their design is based on when you do the install. |
12-29-2005, 08:29 PM | #122 | |
12-29-2005, 10:48 PM | #123 | |
01-12-2006, 02:36 PM | #125 |
1. S13/with sunroof
2. Sparco Sprint 3. somewhere around $200 shipped I think 4. Bucket 5. Bride MO 6. none, Bride bracket is costly but nice to have.I only had to buy 2 10x1.5?(Ill look it up later) bolts for the back two holes on the seat, bride included ones for the front two holes. 7. 5 7 170 8. Headroom ok? yup 9. Its not uncomforable, but Ive sat in better seats. But the price was right 10. Ill get pics if my I can ever get my camera back The only thing I can say that Im not really happy about with the Sprint/Bride MO setup is; as short as I am when I have the seat in a position to where my feet feel good on the pedals the steering wheel needs to be moved up more then Id like it to be. Its not as bad as a semi steering wheel but if I place it where I normally do it rubs my legs. |
04-20-2006, 01:06 PM | #126 |
1. S14 no sunroof
2. Bride Zeta II 3. $820 after tax and shipping 4. Bucket 5. Bride FG rails 6. Bracket mods required - none 7. 6' 170lbs 8. Headroom = plenty with helmet 9. Seat fits my frame perfectly. I won't like it if I gain 10lbs. |
07-20-2006, 01:53 AM | #127 |
what would be the lowest bracket for most reclinable or bucket seat?
i am selling my Status seats and one of the main reason was the seat position. it was too high for me. |
07-20-2006, 01:57 AM | #128 |
reclinables and buckets use different rails
but the answre is the same in either for most seat brands (if they fit the seat): A) custom B) BRIDE done and done. |
07-20-2006, 02:40 AM | #129 |
what seat do you guys think would be best for me...im 5'11" and 240lbs....waist is 36 and i have big legs...i guess finding a seat that fits my waist is easy, but legs are the hard part for me...i would like to drift without my balls being smashed lol...
07-21-2006, 12:57 AM | #130 | |
06-05-2007, 03:57 PM | #132 |
I'm gonna revive this thread with my latest setup...
1. S13 Moonroof 2. Recaro Pole Position 3. $649 @ hmsmotorsport.com 4. Fiberglass Bucket 5. Nagisa Rails 6. No modifications to rails 7. 5'5"; 38" waist, 210 lb. 8. Lots of headroom w/o helmet. 1 inch or so w/ helmet 9. I consider myself rather large and I feel like I have the perfect frame for this seat. It feels like a moderate hug all around and I don't move around at all during hard cornering. Anyone larger than 38" might not fit. Shoulders are also perfect. Although, a friend with a similiar waist to my own and is about 6'4" had issues with the shoulder portion, but the waist and the butt area was fine. 10.
D-Street.net | bcuison.wordpress.com |
06-06-2007, 08:57 AM | #133 |
1. S13/S14/sunroof
S14 without a sunroof. 2. Seat Manufacturer/Model OMP RS Seat 3. Price of seat $450 shipped from www.tankslapperautosport.com 4. Bucket/reclinable Bucket 5. Bracket used Bride FG from Logan @ Aspec 6. Bracket mods required None, but the seat tilted to the left from a bird's eye view. I had to force the seat to open up to the right to get a cleaner line to the gas pedal. I set the front to the lowest setting and the rear to the middle. The gangster lean is in full effect. 7. Driver's height and weight 5 feet 11, 220 pounds 8. Headroom ok? Wonderful with and without a helmet. 9. How does seat fit you, ie will someone bigger/smaller fit ok? It fits tight on the waist area. I plan on losing at least 20 pounds so I can fit alot more comfortably. The shoulder area is wonderful. 10. Pics Carlos |
08-30-2007, 01:47 AM | #134 |
1.S14 without a sunroof.
2. Recaro , Original Equipment on Evo 8 3. £350 /$700 both fronts, rear , & door cards 4. Reclinable 5. Bride superlow base mounts (s/h £100/$200 for both) 6. added flat metal bars across the bottom of the original seat mounts and bolted through the rails in to the bars 7. 5'3 90kgs 8. Loads of headroom 9. Seat fits snugly, 38" waist, any bigger would not fit, going to have to loose a little weight, front seat hight is about 1-1.5cm higher than std. Seat is much more comfortable. Rear seat is an a std S15 rear seat (£50/$100) in the Jersey fabric, goes ok with the fronts untill i can get it recovered with the original recaro fabric from the evo. C.
08-30-2007, 08:28 AM | #135 |
Ok i know i win for the Most NON Jdm seats ever.
1. S13/sunroof taken out 2. Kirkey Intermediate Road Race 3. $250 for bucket, $150 for cover 4. Bucket 5. Custom brackets or bottom or side mount. 6. no mods 7. Seats range in sizes so just try a few to see which fits(250lb 16in seat) 8. TONS of head room, you can mount these seats as low as you want. 9. Seat fits great, i went on a 3 hour trip and was fine, a lot more comfortable then i expected. 10.
nissan tech Last edited by driftenthusiast; 08-30-2007 at 04:53 PM.. |
08-31-2007, 12:36 AM | #136 |
I'm looking for a reclining seat for a s14. I'm 6'3,250 lbs,40" waist.I ride reclined with stock seats now so I don't scape my melon.For sure don't want my balls crushed either.If you're close to my size let me know what seat and rails you're runnin' Thanx.
08-31-2007, 04:24 AM | #137 |
1. S14 with sunroof
2. Recaro SPG (driver) Recaro SR111 (passenger) 3. 35,000 yen/ came with car 4. Bucket/ Reclineable 5. Unknown sidemount/ Juran bottom mount 6. None/ Recaro brackets 7. 5'10 180 lbs 8. plenty of headroom even with a helmet/ shorter people have trouble seeing over the dash in both seats. 9. Seat could be tighter 10. |
09-22-2007, 10:59 AM | #138 |
Ok I looked through this thread but didnt see anyone with my kind of seat I dont think
Im trying to find a Slider rail for my Recaro Sport Reclineable fo my S-13 (USDM Driver side) 406 mm Wide X 297mm length <--Mounting Bolts Ive been looking at the Bride Type MO but cannot find Dimensionsfor it, I mailed the Guys @ A Spec but I got no reply from them yet. So if anyone knows the Dimensions for the Bride Type MO Slider can they PM me? Thanks
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
09-22-2007, 12:36 PM | #139 |
Iv sat in a lot of seats but this is by far most comfy bride seat.
Bride Gias Lowmax Carbon Kevlar. (softer without the gradation material) Higher front leg cushion. I have driven 20 Hours+ straight, with minor brakes in this seat. Uses the Bride Gias Lowmax Rail(lowest bottom mount rail out there) Worth its msrp It could be lower, like the VIOS III with Low Max Side Mount rail (one of the lowest buckets out there.
@woooster on instagram |
09-22-2007, 12:52 PM | #140 | |
Both your seats look pretty high? Is it just the side bolsters are tall and it's creating an optical illusion?
Look directly above your post and you'll see a Recaro SR111 in my passenger side. |
09-22-2007, 01:43 PM | #141 |
1. S14 no sunroof
2. Recaro SPG 3. $600 used mint condition 4. Bucket 5. Nams super low rails 6. no mod brackets 7. 5'8" 180lbs 8. good headroom, rails are on middle bolts, and not lowest... 9. seat fits me great, super comfy... i can't get any fatter though... 10.
11-23-2007, 07:58 AM | #143 |
1. S13/no sunroof
2. Bride GIAS III 3. WAYTOOFUCKINGMUCH 4. Bucket 5. Nagisa Sidemount Ultra Low Seat Rails 6. NONE 7. 5'11/200lb 8. yes 9. Custom ordered (not standard GIAS III) |
11-23-2007, 08:01 AM | #144 | |
11-23-2007, 11:58 AM | #145 |
I bet no one was expecting this to show up!
1. S13 with no sunroof 2. VIS carbon fiber 3. about 500 4. kicked the bucket 5. Bride sidmount 6. need to cut the front mounts to make the front sit one more notch lower 7. 5'10 and 160 lbs - 32 inch waist 8. headroom - pretty close to the top, but that is because i have a long torso 9. fit- it fits me perfectly. anyone bigger than 32 inch waist is gonna get stuck in it though. also, its got a pretty bad lean on it so i need to put the front down more. |
11-23-2007, 01:26 PM | #146 |
1. s14 hardtop
2. corbeau trs(wide) 3. Price of seat 640 shipped pluss 200 for wide option 4. reclinable 5. custom 6. yes. used fctory brackets with a few mods 7. 5"9 240lbs 8. with helmet on no. daily yes. with cage installed no anytime 9. seat fits good. side bolsters could be higher. defiantly a street friendly seat minus the fact u side 1 inch or more higher than factory. causing head room issues(if you have a cage get a bucket with the lowest mounts possible 0 10.
Mouth of the South There are a few mailboxes that have been looking at me the wrong way, lately. Nothing goes unchecked. |
11-25-2007, 11:03 PM | #147 |
heres mine
1. s14/sunroof 2.jic magic 3.paid $250 when shop was closing 4.reclinable 5.jic sliders $160 6.no mods needed 7.5,8 170 lbs. 8.plenty of head room for me , but i try to scoot down in the seat as low as i can 9.fits me good , hurts my ass on long trips though,
"NIGHTSHIFT-GARAGE" |
11-25-2007, 11:18 PM | #148 |
hey guys,
ive been lookin around for a seat that would fit nicely...so i thought i'd give a shot asking here. Im 6'1" about 190lbs...thing is..the hips are a little wide..so fitting into bucket seats is kinda a pain for me. ive ridden in bride ergo I's before, and couldnt take very long of it...same goes for sparco bucket seats. I know the bride xax is out there...but i'd like something with a little more support for the legs. I've been told to look into recaro...any thoughts/ideas?
11-26-2007, 12:03 AM | #149 |
1. S14 with sunroof
2. BRIDE Ergo II 3. search froogle.com for pricing 4. Reclinable 5. Custom Bracket 6. Metal rails and a drill for fabbing. 7. 6' 190lbs. 8. Good headroom 9. Seat is nice and snug, wouldnt recommend this seat for anyone over 230lbs. 10. Pics
11-26-2007, 01:43 PM | #150 |
1. S13 coupe/no sunroof
2. Sparco EvoL 3. $650 shipped for the pair (Ebay) 5. Home brewed bracket, required for me to fit with a helmet and NOT have to cut the floor board 6. See pictures below 7. 6'4", 190lbs, 34" waist 8. With helmet off (bottom pad installed) 3-4" With helmet on (bottom pad removed) 2-3" 9. I fit fine in the seat, I owned an Evo before and that was alittle on the tight side. I'd say anyone up to a 36" seem would be fine... 10. Pics Drivers side bracket before welding on the L brackets to the 1/2" solid rod for mounting the seats to. I'd say this is as low as you can you go in the front without cutting or pounding... Seats installed, here you can see the side mount brackets, they are 1/4" thick and are very solid once everything is mounted. Last edited by McCoy; 11-26-2007 at 01:44 PM.. Reason: addition of ebay for purchase |
