Old 05-09-2008, 01:36 AM   #1
zaneithan
zaneithan's Avatar
zaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to behold
speedometer wont work
ive searched threads over and over again and still cant figure out what exactly is wrong...
the car is a redtop sr swapped 92 s13 that was originally automatic, wiring harness was sent out to yury to be wired.
lower wiring harness is hooked up to all sensors
the speedometer refuses to work, it reads nothing, im stumped as to what it could be...i apologize for posting yet another speedometer question but i cant figure it out even after looking at countless threads
thank you.
1993 240sx fastback (wrecked)
1991 240sx SE fastback Daily Driver status
1992 240sx fastback (???)
1986 Toyota Corolla SR5 Coupe (sold)
zaneithan is offline   Reply With Quote
Old 05-09-2008, 01:41 AM   #2
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
it may be the speed sensor... check that out
chetacheese is offline   Reply With Quote
Old 05-09-2008, 02:16 AM   #3
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
as above check to see if your speed sensor is sending a signal. it might be faulty. i don't know if it's the same on an sr tranny because i don't have one - yet, but it might be the same as checking it on a ka m/t s13 like below.
I CAN FLASH MODIFY YOUR XBOX 360.
Modrified is offline   Reply With Quote
Old 05-09-2008, 05:02 AM   #4
drkidd22
drkidd22 is an unknown quantity at this point
SR
This is what you need to to first.
1.Check your speed sensor per the FSM.
If that doesn't work check all your connections related to the speed sensor. It doesn't matter who made your wiring hardness. Mistakes happen. Just test for continuity. It shouldn't take you more that 30min. less if you are really familiar with schematics and electronics.
If nothing works let me know what you can find out.
drkidd22 is offline   Reply With Quote
Old 05-09-2008, 11:39 AM   #5
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
does your tach work?
97 240sx se
0wn3r is offline   Reply With Quote
Old 05-09-2008, 01:47 PM   #6
zaneithan
zaneithan's Avatar
tach works fine, im gonna test the vss itself, thanks for the help everyone
Old 05-09-2008, 03:13 PM   #7
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
The speedo itself could be broken. Swap out with a known good if possible.
g6civcx is offline   Reply With Quote
Old 07-02-2008, 07:27 PM   #8
zaneithan
zaneithan's Avatar
big bump....changed out speedos, still not working, any other suggestions?
Old 08-28-2008, 10:35 PM   #9
yeti303
yeti303's Avatar
yeti303 is an unknown quantity at this point
haha same here mine doesnt work i replaced it and tested the one i yanked off, its good so im guna follow the wire up to the dash and see if its discontected some how or im guna swap the cluster...
yeti303 is offline   Reply With Quote
Old 08-29-2008, 12:03 PM   #10
0wn3r
0wn3r's Avatar
do you have a manual transmission speed sensor or the stock automatic?
97 240sx se
Old 08-30-2008, 10:14 AM   #11
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
The stock auto speed sensor does not fit. Its bigger than the m/t one.
I know, that cost me an extra week and a half on my five speed swap.
Do you suffer from vaginal dryness...
Pblesh85 is offline   Reply With Quote
Old 08-30-2008, 10:55 AM   #12
Row
Row is an unknown quantity at this point
I had this same problem before. The speedometer itself crapped out, I picked up another one at the junkyard. Hope this helps.
Row is offline   Reply With Quote
Old 08-30-2008, 11:46 AM   #13
don_bagz
don_bagz's Avatar
don_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to behold
like i said on somebody's thread too.. check your speed sensor pinion.. coz mine did the same thing, i changed out the speed sensor, but still didnt fix the problem. then i found out that my pinion gear was worn out. got that changed, so, now my speedo is fixed
don_bagz is offline   Reply With Quote
