Old 10-28-2007, 02:30 PM   #1
ZilviaBot
Zilvia.net Bot
Post Nissan GT-R technical details
Filed under: Tech, Supercars, Nissan
Click the above image for 26 high-res photos of GT-R parts.
The new Nissan GT-R is an engineering playground. We hope to get our chance to play with it soon, but until then, we get pictures. Luckily, Nissan has released detailed images of the GT-R drivetrain and suspension. These reveal some of the alterations made in the GT-R design from prior models. One of the more significant changes is the placement of the transmission. The dual-clutch transmission and combination transfer case sit at the back of the car, coupled to the rear differential (that makes it a transfermissiondiffcase). It makes for more balanced weight distribution with the transmission, rear differential and transfer case counterbalancing the weight of the engine and front differential.
The turbochargers have also changed from Garrett units used in past GT-R models to IHI, a Japanese-owned company. The turbine housings (aka hot side) of the turbochargers are a combined casting with the engine exhaust manifolds. Most likely this is done to save space and for emissions reasons to ensure the catalytic converters are as close to the turbocharger outlets as possible. Each turbocharger is followed by two catalytic converters, making for a total of four. Two intercoolers are also installed, as opposed to one with two inlets, keeping the charged air for each bank of cylinders constantly separated. This is most likely done to ensure precise metering of air.
[Source: Nissan]Continue reading Nissan GT-R technical details
Â*
Permalink | Email this | Comments
More...
Old 10-28-2007, 10:04 PM   #2
mr.lonelys12
mr.lonelys12's Avatar
mr.lonelys12 is a jewel in the roughmr.lonelys12 is a jewel in the roughmr.lonelys12 is a jewel in the roughmr.lonelys12 is a jewel in the roughmr.lonelys12 is a jewel in the roughmr.lonelys12 is a jewel in the roughmr.lonelys12 is a jewel in the rough
Send a message via AIM to mr.lonelys12
that picture is amazing!
... although you cant click on it for the additional 25 pics.
mr.lonelys12 is offline   Reply With Quote
Old 10-29-2007, 12:38 AM   #3
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
I still f'n wanna know about the launch control...
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
HTML code is On
