![]() 1991 JDM Nissan Silvia
Unknown Miles I purchased the car February 2018 from JDM Classics Llc in Richmond, Virginia. I have been building this car with the purpose of autocross and HPDE. Things in life change (House, Deployment) and I have decided to put the car up for sale/trade + cash. I have installed many new parts in the last 4 months. I have the clean NC title. I will attempt to list everything. I could remove a few pieces to reduce the price of desired (Wheels, Coilpacks, AEM Dash). I am asking $19,000 OBO. I will consider a cool trade plus cash. Engine: SR20DET (I was told it is a 2.1L built in Japan, when I bought it from Japanese Classics, but no paperwork to confirm it. When I changed the oil pan the motor looks brand new, and the pistons were machined instead of cast, compression is low 170?s across all cylinders). Mazworx G25-550 Turbo kit Super RARE Ikeya Formula Intake manifold w/ ITBs Ikeya Formula Fuel Rail Custom 3 in intercooler piping Trust FMIC Turbosmart Constant tension intercooler clamps Tial BOV Tomei 256 Poncams Mazworx Headtuds Tomei HG Mazworx Billet Timing Chain Tensioner S13.4 Valve Cover w/ -10an Fittings and lines True Focus Fab oil catch can/ coolant overflow combo Greddy oil pan S15 oil pickup Trust oilfilter relocation earls oil cooler -10an lines -20 an Radiator hoses Chasebays tucked radiator w/raceline fans PRP R35 GTR coilpack kit Wiring Specialties Coilpack Harness Touge Factory Pulleys HKS belts Chasebays Power Steering Kit Fuel: Modified Stock Sending Unit with -8an feed and return Hellcat 450lph pump Vibrant -8an Black E85 Hose feed and return JEGS 10 Micron Fuel Filter Ikeya Formula Fuel Rail Radium Engineering FPR FIC 1650cc High Z Injectors Driveline: OS Giken Twin Disc Clutch Stock SR 5 speed with short shifter 2-way LSD(came in car from japan) Electronics: AEM V2 MAC Solenoid to control boost AEM CD5 Dash w/GPS Custom 3D printed cluster Innovative Ethanol Guage AEM Wideband O2 Guage Rare Veilside fuel pressure and Voltmeter guages in dash on passenger side(came from japan this way) 6-channel AEM Can sensor module(to convert the fuel level signal for the AEM dash) Suspension: Yellow Speed Racing 2-way pro sport coilovers GK Tech Front one piece LCA and Tension Rods Sikky Front sway bar GK Tech inner and outer tie rods GK Tech RUCAS GK Tech Chromoly Rear Knuckles GK Tech Rear LCAs GK Tech Toe Arms GK Tech Traction rods Rear Strut tower Brace Bolt in Cusco 4 point Cage New wheel bearings GK Tech 15mm bolt on spacers Brakes: Yellow Speed Racing 6 piston front calipers w/ 356mm rotor Yellow Speed Racing 4 Piston rear calipers w/ 330mm rotor Chasebays Brake Booster delete with Wilwood master cylinder and proportioning valve Interior: Sparco Grid Q Seats on Sparco seat brackets Sparco Steering Wheel NRG quick release hub Uncracked Dash G-force 5 point Harnesses Has Heat, No A/C Exterior: CCW Race Classics w/ Black face and Hand Polished lips 17x10 +10 Front w/ 255/45/17 Falken Azenis RT615k+ 17x11 +10 Rear w/ 275/45/17 Falken Azenis RT615k+ VIS Carbon Fiber hood Race Louvers Hood Vent Proven 90lbs of downforce Custom Front Splitter on quick releases for the track(10mm Alumalite) Body kit that is on it came from japan so your geuss is as good as mine True Focus Fab front bash bar with tow hook Front bumper quick release with 2 10mm and 2 Dzuz fasteners APR GTC 200 Carbon Fiber wing Paint is what I call Bass Boat Blue(came from Japan painted this way) Just had paint corrected and 2 year ceramic coated 1 month ago The car made 320 whp / 280 tq last year on pump gas, 14 psi, and stock cams on a mustang dyno and safe tune. Car is now street tuned on 25 psi and e85. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Found this car being resold online
http://alhamdautotrade.360vinspin.ne...4-c2e93d9637dc Also on Facebook Marketplace near the Charlotte, NC area https://www.facebook.com/marketplace...50679966268226 https://www.cargurus.com/Cars/l-Used...ting=277323270 Shame that the car fell in the hands of resellers looking to make a quick buck by asking 28-30k for it instead of someone that could appreciate it... either that or lots of nigerian scammers using the pics lol Also this car was originally for sale for $14,495 at Japanese auto classics on February 21, 2018. (found it on their instagram) |
#6 | |
![]() Join Date: Aug 2005
https://www.facebook.com/marketplace...03433121058608 |
