Old 03-25-2020, 06:20 PM   #1
Thursday7
Thursday7's Avatar
Why is there no solid answers on SR oil restrictors?
How the hell are there so many well running, simple setup SR's running stock turbos, but I can't get a simple answer on running a restrictor? Are yall just guessing?
Turbo: Stock S14 T28. 14411-69f00. I'm 90% sure this is a single ball bearing turbo. I currently run a .06" restrictor as my previous research has led me to believe is correct, but upon removing my turbo after 1 drift event, the hot pipe is very oily inside. I don't know if this is due to blown seals or an improper restrictor. No amount of googling is giving me a solid answer for which restrictor to use while running a 69f00.
I don't want wives tales. Does anyone have a solid fucking source as to what is correct here? I don't want to play a game of "that thread sucks and is misleading". I will kiss your toes and call you daddy if you provide a thread that says my googling skills are bad.
WTB Bride Zieg II
Old 03-25-2020, 06:59 PM   #2
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
Garrett website.
"An oil restrictor is recommended for optimal performance with ball bearing turbochargers. Oil pressure of 40 ? 45 psi at maximum engine speed is recommended to prevent damage to the turbocharger?s internals. In order to achieve this pressure, a restrictor with a 0.040? orifice will normally suffice, but you should always verify the oil pressure entering the turbo after the restrictor in ensuring that the components are functioning properly. Recommended oil feed is -3AN or -4AN line or hose/tubing with a similar ID. As always, use an oil filter that meets or exceeds the OEM specifications.
OIL LEAKAGE SHOULD NOT OCCUR ON A PROPERLY FUNCTIONING SYSTEM IF RESTRICTOR IS NOT USED UNLESS THE SYSTEM PRESSURE IS EXCESSIVELY HIGH."
Straight from the mfr. Why don't people think to look to the company that manufactured their parts for recommendations and specifications for proper operation? And it isn't different on every individual turbo. Garrett manufactures their turbos to a general set of operating conditions for cooling and oiling.
So, as always, it depends. The oil pressure is key here. Can you run a bb turbo with no restrictor? sure. If your oil pressure is below 40-45 psi. What size of feed line are you running? what side of drain line? if there is a restriction in the drain, the pressure the turbo will see increases. There isn't a blanket yes/no answer.
Example, I see about 65 psi oil pressure when my engine is cold at cruising rpms (3.5K ish) but when the motor heats up that'll go down to 55-57 as taken at the oil filter block. I need a cooler setup but, with a -4AN line and appropriately sized adapter on my BW journal bearing turbo, I have no issues.
TL;DR - it depends, but, measure your oil pressure at the feed line. .060" may be too large if pressure on the turbo side is exceeding 40-45psi peak (I read drift so, I'm guessing that's a yes.)
Also in for people who operated outside of this just fine. That'll happen too. This is just Garrett's recommendation, not absolute law.
NukeKS14 is offline   Reply With Quote
Old 03-25-2020, 07:23 PM   #3
Thursday7
Thursday7's Avatar
Thank you. This is a good start. When drifting my oil pressure often exceeds 60psi at the oil filter block. My oil drain is plenty adequate.
I guess I'm also looking for a solid answer on the turbo itself. I cannot find hard evidence as to if the 69f00 is ball bearing or not. I plan on disassembling this weekend but getting some knowledge during the week would be nice.
WTB Bride Zieg II
Old 03-25-2020, 08:26 PM   #4
NukeKS14
NukeKS14's Avatar
That part number is for an rb20det skyline turbo
https://www.garrettmotion.com/turbo-...ching=UNLINKED
Old 03-26-2020, 05:46 AM   #5
Thursday7
Thursday7's Avatar
Not sure where the inconsistency is here, but I'm sure dozens of people here could vouch for the 69f00 being a turbo from SR's, whether or not its the same as a skyline. I always assumed skyline turbos were T3. Maybe they have the same CHRA and housing A/R's, therefore Garrett seeing it as the same thing?
WTB Bride Zieg II
Old 03-26-2020, 06:27 AM   #6
NukeKS14
NukeKS14's Avatar
https://jp-carparts.com/nissan/partl...1169F00&page=1
Yeah. Weird.
"The first number is a batch number, it tells you when/where it was built
The second number is the "oem" number. On a nissan turbo it's a nissan part number, on an HKS turbo it's an HKS part number, on a garret turbo it's a garret number, on a Tomei turbo it's a tomei number etc etc. 14411-69F00 is a nissan part number.
The last number is a chra number. 466541 is a ball bearing cart with a 60 trim 60mm comp wheel and a 62 trim 53.8 mm turbine wheel, 466543 is a brush bearing cart with the same wheels. On this particular turbo the second part of that number describes what turbine housing is used. If it ends in 01 it means the "normal" turbine housing, if it ends in 02 it means the S15 turbine housing "
So could be bb could be journal. What are the rest of the numbers from the plate?
http://www.nissansilvia.com/forums/t...t-is-my-turbo/
Old 03-26-2020, 10:36 AM   #7
Thursday7
Thursday7's Avatar
That's going to have to wait. I memorized the part number but will have to go back to my shop before seeing the plate again.
WTB Bride Zieg II
Old 03-26-2020, 10:51 AM   #8
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Late Zenki and Kouki S14SR’s came equipped with BB turbo’s. There may be a random journal bearing turbo in the mix.
I contacted Garrett directly for answers pertaining to oil feed restricters. I believe I have a .044 or there about a on my GTX3076R. My oil pressure is also 80-85psi under load and has seen spikes above 100psi. -10 AN drain and I’ve had zero issues.
My SR20VET
Old 03-26-2020, 01:12 PM   #9
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 is an unknown quantity at this point
Feedback Score: 18 reviews
For the stock SR20 turbos, most oil line kits come with two sized restrictors.
1.6mm / 0.062" for journal bearing
or
0.8mm / 0.032" for ball bearing
Using the larger restrictor on a ball bearing turbo can blow out the seals.
LoSt180 is offline   Reply With Quote
Old 03-27-2020, 09:06 AM   #10
TheRealSy90
TheRealSy90's Avatar
or
Uhm not necessarily.
DIF lines and many others come with 0.06" restrictor for journal bearing and 0.04" restrictor for ball bearing.
https://diftech.com/products/bottom-...nt=16883594374
I use the 0.04" restrictor on my S14 ball bearing turbo.
Such a good signature.
Old 03-27-2020, 11:04 AM   #11
Thursday7
Thursday7's Avatar
DIF lines and many others come with 0.6mm restrictor for journal bearing and 0.4mm restrictor for ball bearing.
I use the 0.4mm restrictor on my S14 ball bearing turbo.
I hope you mean 0.04in? .4mm (.015in) is smaller than any restrictor I've seen.
I was thinking about going down to a 0.04in. I'm currently using an unrestricted 4AN braided line and a .06in restrictor and there's a lot of oil. Going to take my turbo apart before buying anything though.
WTB Bride Zieg II
Old 03-27-2020, 01:23 PM   #12
TheRealSy90
Yeah typo, I meant 0.04" and 0.06".
Old 03-28-2020, 12:56 PM   #13
Thursday7
Thursday7's Avatar
Yeah. Weird.
At my garage now. Tag is a 466541-7001. So ball bearing, S14 turbine housing. Exactly what I was speculating, cool. Gonna order seals and a smaller restrictor, should do me good.
Thanks Nuke and Sy.
WTB Bride Zieg II
Old 03-28-2020, 02:33 PM   #14
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
I currently use a .035 on a gt28rs turbo. https://www.atpturbo.com/mm5/merchan...egory_Code=RES
Next turbo setup i do, I probably will use one of these. https://www.turbosmart.com/product/opr-t40-40psi-black/
@adamcs14
NiSilS14 is offline   Reply With Quote
Old 03-28-2020, 06:16 PM   #15
NukeKS14
NukeKS14's Avatar
Now that is slick. I didnt know those existed. I just grabbed one of their wastegates and they make some nice stuff. Bookmarked.
