![]() Join Date: Aug 2007
fuel pump direct battery power
I have been advised that i should wire my fuel pump dirctly to the battery to reduce voltage drop. Can i just use the existing power source for the pump to trigger the relay and power the pump? Is it really that easy? Obviously i still have to wire up the rest of the relay but is that it? Thanks
If voltage drop through a relay was that much of a concern then they wouldnt be used at the factory. Dont wire it directly to battery power,just use the existing setup.
Baling Wire-The Duct Tape Of Champions |
I already have the battery in the back as it is, i would be using the factory fuel pump wiring as the trigger for the new relay to directly connect the pump to a good 12v source
![]() Join Date: Sep 2007
I actually JUST did this. haha
Boost It Up - AP Boss Fuel Pump - Turbo Magazine starting the car up tomorrow lol
![]() Join Date: Aug 2005
Trader Rating: (60)
![]() Feedback Score: 60 reviews
http://www.painlessperformance.com/Manuals/50102.pdf
Here's the kit I'm installing this week. I've been having fuel pressure drop after 6K rpm. I've narrowed it down to voltage drop so hopefully this fixes it.
Instagram: @garagelu |
I dont know... Im personally not a fan of running more wiring around my car that isnt absolutely necessary. Plus, if your having voltage drop problems with the factory wiring wouldnt it make sense to just fix the existing wiring, rather than to have bad wiring control a new relay?
Do you really want to go thru the whole car tracing the fuel pump power wire just to replace it?? when you could just run a new one and tuck it nicely or something?
And the old wiring still works, just doesnt hold the strong 12v at all times. The old wiring is only clicking the relay on, should do the job just fine.
you could do this, but it requires a little more cash.
Kenne Bell Boost-A-Pump |
#12 | |
![]() Join Date: Mar 2006
IIRC, the factory setup has the fuel pump in a circuit with other things, and as the load on the car changes etc etc you can more easily get inconsistent voltage. I measured the fuel pump voltage under my "OEM" wiring setup and I see about 12.5 volts. However, the alternator puts out close to 14V when the car is running, so you should be able to utilize that advantage by wiring directly to the battery and getting 13.5-14.0 V to the pump.
![]() Daily driven |
#13 | |
![]() Join Date: Mar 2008
Could you essentially just find the power wire off the sending unit, cut and splice into a power source on ignition? Or does it need to go through the relay? Where's that specific relay?
IG: @vsMARTINO |
#14 | |
The easiest way to do it is to use the OEM power wire running to the fuel pump as a TRIGGER on the coil side of a NEW, second relay. Then, run the power to that relay DIRECTLY from the battery (if it's in the trunk that is cake). This way you get the maximum voltage possible to the battery
Im having issues with my fuel pump and I wanna directly wire it to the batt and after reading this I understand what I have to do. But I do not understand what wires go to where. If someone could post a write-up or pm me a step by step process on what wires go where that would be great. Thanks in advance, sorry if this is a "noob" post..
#17 | |
I'm looking to do this exactly, especially because my battery is in the trunk. My only issue is...I'm medicore at wiring and every diagram I've looked at confuses the fuck out of me LOL Any godly chance you could ghetto rig me a diagram? haha. <3 love you long time.
IG: @vsMARTINO |
Terminal 86 - Ground
Terminal 30 - Direct to battery with inline 30A fuse Terminal 85 - B/Y wire from pump (trigger) Terminal 87 - Other end of B/Y wire (trigger) I think this is correct just unsure if i have the trigger wire correct. |
#20 | |
Okay get a NEW relay that can support the current (not sure how much). You cut the power and ground wires going to the pump. Run a new, thicker ground from the pump to chassis. Take the OLD pump power wire, and run it to the + side of the coil on the relay. Run another wire from the ground side of the coil to the chassis. Run a wire from the battery to the switched side of the relay, and then another wire from the other switched side of the relay to the + terminal of the pump. IIRC, the current dircetion through the relay doesn't matter (wait for someone else to confirm this)
#21 | |
Continuing: http://4x4icon.com/offroad/headlight...ay_diagram.gif 85: this is where you would wire the power wire of your existing fuel pump wiring as the trigger. 86: this you would wire to a reliable chassis ground. 30: Wire your power wire from the battery here. 87: Run the power wire to your pump from here.
#22 |
![]() Join Date: Oct 2004
Thanks MAN!!! I just ordered this.... I didn't know a kit existed....
Plug and play is the best and it was $30 + 13 shipping.... Great thread, never checked for voltage drop, but since I do a lot of trackdayz I should have thought about this.... Great thread!
#23 | |
And I just read that over again... Still confused...I tried drawing a diagram of what you explained but I'm doing something wrong. Ugh.
IG: @vsMARTINO |
#29 | |
I sure hope not. This mod has left me stranded before. Bosch 40amp relay crapped out on me pretty fast. |
#30 |
![]() Join Date: Dec 2004
Trader Rating: (58)
That's a very rare occurance to be honest, only time I've ever had issues with relays failing (other than the random OE ones dying at the shop) are when I had some installed upside down (connector up) and rain water getting in them on a little off road buggy i had.
