Old 11-25-2017, 11:35 PM   #1
BadazzSr20
BadazzSr20's Avatar
BadazzSr20 is an unknown quantity at this point
S14 steering wheel question?
I’m looking at a few steering wheels just want to know All I need is the NRG short hub and a NRG quick release? I’m looking at this steering wheels as of right now?
http://www.jegs.com/i/Grant/470/673/10002/-1
97 240jz
BadazzSr20 is offline   Reply With Quote
Old 11-25-2017, 11:57 PM   #2
anthony_240
anthony_240's Avatar
anthony_240 is an unknown quantity at this point
Yes. Don’t need a quick release but a nice add on
anthony_240 is offline   Reply With Quote
Old 11-26-2017, 07:58 AM   #3
BadazzSr20
BadazzSr20's Avatar
Thank you very much!
97 240jz
Old 11-26-2017, 11:50 AM   #4
derass
That wheel won't work the NRG parts, different mounting bolt pattern. Maybe you can get an adapter. The NRG hub has the Sparco type mounting pattern. The Quick Release has both Sparco and Nardi style.
The NRG Short Hub is short to work with the Quick Release, which is long. Using it by itself will put the wheel farther away from you then stock. Using them together will bring the wheel closer than stock.
Another option is a standard hub from either Works Bell, Sparco or HKB. This will put the new wheel approximately where the old one was.
