Old 04-12-2002, 01:51 AM   #1
fungus
fungus is an unknown quantity at this point
Send a message via ICQ to fungus
About how much do they weigh and what is the bolt pattern?
Just though about power coating them black and doing a 5 lug conversion for my 240. What is needed for a 5 lug (money wise)?
Red 91' 240 SX Fastback - SE, LSD, HICAS.
Mods: strut tower bar, japanese radiator cap (from japan!).
Plans: To run with the big dogs. 10's, 1.0+G skidpad.
fungus is offline   Reply With Quote
Old 04-12-2002, 01:56 AM   #2
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
Parts needed for 5 lug swap:
S14 SE Front spindle/knuckles
S14 Knuckle to Strut Mounting Bolts ( Some have used S13 bolts)
S14 SE rear Hub or Z32 Non-turbo rear hub (both will work, only hub)
*S13 will need a S14 ball joint pressed into the control arms (ONLY S13)
S14 SE rear rotors.
You’ll also need more lug nuts.
And a set of 5 lug pattern wheels.
I just sent out a set of Z32 rims to get coated, I'll post a pic for you when I get them back.
Kid Zelda is offline   Reply With Quote
Old 04-12-2002, 04:54 AM   #3
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
Send a message via AIM to Grant Send a message via MSN to Grant
Hey Kid Zelda where did you get em powdercoated? How much?
Grant is offline   Reply With Quote
Old 04-12-2002, 09:01 AM   #4
ledzep
ledzep is an unknown quantity at this point
They weight 16 lbs a piece.
1993 300ZX NA.  Stage 1+
ledzep is offline   Reply With Quote
Old 04-12-2002, 12:03 PM   #5
fungus
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Kid Zelda @ April 12 2002,02:56)</td></tr><tr><td id="QUOTE">Parts needed for 5 lug swap:
S14 SE rear rotors.
I just sent out a set of Z32 rims to get coated, I'll post a pic for you when I get them back.</td></tr></table><span id='postcolor'>
so how much $ am i looking at for the 5 wheel conversion?
also, i'd really like to see some pics when you get em.
